Hi from United kingdom,
Please can I have your help guys, lost code for Porsche Becker serial no X5011122.
Many thanks Geoff
7 hours ago, Loren said:
Try 9086
Perfect, thank you very much for your quick reply.
Reg Thor
25 minutes ago, Geoff 996 said:
Hi all,
May I have some help with a lost code Becker serial no X5011122
Many thanks
Geoff
Try 4370
Hi there guys.
The battery of my Porsche 996 was recently disconnected and it didn’t come with a radio code when I bought it from the previous owner.
It’s a BE 2560 PCM radio
Serial number: X5025286
I would greatly appreciate the radio code if you have it. Thanks.
2 hours ago, Romano Naidoo said:
Hi there guys.
You did not read the Lost Radio Code FAQ ?
"Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/ OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/ OPC."
46 minutes ago, RT Davis said:
Hi Loren,
Radio code needed please.
Becker CDR-220
type 4462
Model CDP2081
Serial X5036460
Thank you for your help!
Try 7381
Hi Loren,
I'd be grateful if you could find me my radio code please.
Becker CDR220
Type 4462
Serial X5021940
Thanks very much!
7 hours ago, UK2UT said:
Hi Loren,
Becker CDR220
Type 4462
Serial X5021940
Thanks very much!
Try 4741
Try 4741
That worked. Thanks very much, Loren!
Edited by UK2UT
Forgot to include quote
Hi.  Same problem.  Replaced battery but no owner's manual or information from previous owners!
1999 Boxster:  VIN: wp0ca2986xu622524
Becker CDR220
Type: 4462
Serial:W5005320
Eric
Still struggling with this and I can't get the code. I called my local dealer 3 times and they never return my call. If you can help please.
It is a Becker 1
Type 4462
Serial# 25017566
Becker CDR220
Type: 4462
Serial:W5005320
Eric
Try 2867
