10 hours ago, Carrerafanatic said:
Hello - Looking for radio code for the following:
CDR 220
BE 6625
15006827
Thank you so much.
Try 9053
3 hours ago, Omes986 said:
Kindly requesting some assistance for the radio code:
Model: CDR220
Type: 4362
SN: 15031478
thanks in advance!
Sent from my iPhone using Tapatalk
Try 8724
18 minutes ago, Alexander Österström said:
Hi. Is there anyone who can help me get the codes for both pcm unit and navigator? It would be so nice 🙏
radio
Typ:IDIS
Model:BE2580
Serial:15092876
NAVI
MLFB:5WK76026
Serial:P022101CB536B
You did not read the Lost Radio Code FAQ...
"Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/ OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/ OPC."
30 minutes ago, bakkenoil said:
New to owning a Porsche and need a radio code for:
Model: CDR-220
Type 4462
SN: 15088313
Thanks for anyone that can help!
Try 6576
I have a 2005 Cayenne Porche and purchased a new radio as mine was stolen. It says "protect" the dealer called Porche but it's been two weeks now with no radio.....can someone please help
You didn't read the Lost Radio Code FAQ ...
"CDR-23 (or later):
These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected."
Hey,
Last year I had some significant maintenance done on my 2000 911 Cab. The shop had to disconnect the battery to perform some of the work and when I got it the radio just displayed the ‘code’ message. I had the issue before and I remembered I was able to get the code on line. I thought I wrote it down but I was not able to find my code. I don’t drive the car often and when I do the top is usually down and the radio off. So now that spring is here I go to take the car for a ride and the battery is dead and won’t hold a charge (after 10 years the battery doesn’t owe me anything). I install a new battery and then I decide to solve the radio code issue once and for all. So I do some searching and find this thread. I record the Radio S/N and then think ‘this is probably the way I got the code the first time.’ So I go to 2010 and sure enough, my post is still there and the code did work. At least I wrote it down!
Thanks Loren! You really are amazing.
Barry
1 hour ago, George993S said:
Hi. I have a 993 with a CR210 that locked after I removed the battery. The serial number is T5001290 . Thank you.
Try 6467
I have a Becker CDR-220 and it’s locked!
Ser - 15006570
type - 4462  thanks in advance!
Edited by Bill237
Hi Loren
I found you via the Boxster owners forum
I have a 1999 type 4467
serial number Y5024605
could you look up the code for it please?
thanks
David
1 hour ago, dt4 said:
Hi Loren
thanks
David
Try 9674
Can someone assist. I just purchased my first porsche...a 97 993 and just getting to know it. Can someone help with radio code for Becker cd210  SNT5002506  Much appreciated....
Try 8758
1 hour ago, Waseem Abo Gazala said:
Help please, my 986 came without the code, battery died and after replacing it, I can't use the radio. It is a CDR22 BE4467 SN X5009908 , I appreciate it.
Try 9635
