Incredible. Thank you, sir...
I read that are missing your 911. I have two from 99, let me know if you decide you want another. If you are visiting NorCal, you can borrow one for your stay.
Back again. Apologies for previously not reading the FAQ.
I purchased a used Cr-210 from eBay, good ol’e fashion tape player
model R3297
Sn-V5008912
Thank you again.
model R3297
Sn-V5008912
Thank you again.
Try 3542
I have a 1999 Porsche Boxter. I also did not know about the radio codes. I replaced the battery today. Now I have the WAIT on the display. Does anyone have the code for CDR 220 ,BE 4462, serial number W5005837 ? I would appreciate it very much. Any help to get the music flowing again.
Thanks in advance for the help.
Dario Villanueva
Dario Villanueva
Try 2908
Hello Loren,
I bought a 2001 Porche Boxster with a blocked stereo. Could you please help me out.
Model cdr-220
Type: 4462
Ser: 15063972
Thank you in advance.
-Yayo
23 hours ago, Jason Caudill said:
How to get code for PCM?
"Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/ OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/ OPC."
On 11/12/2019 at 1:28 PM, YayoM87 said:
Hello Loren,
Model cdr-220
Type: 4462
Ser: 15063972
-Yayo
Try 4617
  • Like 1
Good day. I have a 2005 Boxster
CDR24
model - BE 6645
serial - 55010603
CDR24
model - BE 6645
serial - 55010603
You did not read the Lost Radio Code FAQ...
'"CDR-23 (or later):
These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected."
6 hours ago, Leebee1 said:
BE664575080163
thanks
You also did not read the Lost Radio Code FAQ...
thank you
Thank you for you response. The dealership told me I need the VIN from the vehicle it came from. Do you know if there a way to get the radio working if I person doesn't have the car it came from anymore?  Thanks for your help.
1 minute ago, Rob Gonsa said:
thank you
You will need a shop with a PIWIS to re-code the radio (as stated above).
There are companies who can remove the security from the CDR23.  These people are in the UK, but you can probably find someone in the US:
WWW.DNDSERVICES.CO.UK
Radio Code & PROTECT Repair Service Porsche CDR23 Becker BE 6612 As originally fitted to : Porsche If you are trying to fit this radio to a different vehicle, then you may find yourself with the Error message of "PROTECT".
