7 hours ago, Rwilson said:
Appreciate help recovering lost radio code. Here is the info I obtained from my radio.
Thank You
Just found your site and signed up. Need to spend quiet time with content, if as good as first impression will become a supporter.
thanks again
Becker 1
type 4462
ser# Y5050368
24/99
Try 0876
Hi There!  What a wonderful service. I have
typ: CCR220
Model No. BE6624
Serial No. 15001008
Many thanks
typ: CCR220
Model No. BE6624
Serial No. 15001008
Many thanks
Try 9059
25 minutes ago, Marc St-Laurent said:
Hi, I have a Boxster S 2003 with the radio locked due to dead battery. Hope someone can help me.
Model BE 6612
CDR23
Serial # 25008219
Marc
You did not read the Lost Radio Code FAQ...
"CDR-23 (or later):
These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DMEand can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected."
2 hours ago, Mark Wallace said:
is it just putting the code in and it will work or do i need to hit any other keys
4237 didn't work
Did you get your serial number using the procedure in the Lost Radio Code FAQ? If not, please do so and resubmit the correct serial number.
if you did use the procedure and the code does not work then it is likely that your radio was repaired by a 3rd party (someone other than Becker Sound). If that is the case I am sorry but I can not help you.
Hi
having just bought a  boxster and having the battery replaced the radio no longer works
I have googled to get the model/serial no and have the following info if anybody can help
Thanks in advance
CDR-22
Type:- 4467
Serial :- Y5036253
Edited by Monroe7986
50 minutes ago, Monroe7986 said:
Hi
Thanks in advance
CDR-22
Type:- 4467
Serial :- Y5036253
Try 4972
3 hours ago, Hazeem13 said:
Hi Loren, do you mind helping me out?
I have a CR-220
Type 4362
Serial #: 15040044
Thanks a lot--much appreciated!
Try 0352
I have a CR-210
Type R 3297
Serial #: WS010961
Many thanks!!
Try 8683
