1 hour ago, Halfie said:
Hello
I am trying to find a code for my 986 2002 radio it is
cdr-22
type :4467
ser : 25010305
24/99
CDP2081
Thank you
Try 6787
15 minutes ago, Loren said:
Try 4938
Awasome!! I was almost thrown away.? I will set it on my CARRERA! Thanks  a lot! Arigato gozaimas.?
Lost Radio Code - Thanks in Advance! (Planning to Add an Aux Jack to the Stock Stereo)
2002 Boxster
CDR220 - Becker 1
Serial Number: 15005234
Type: 4462
CD: CDP2081
24/99
Just want to be prepared for when I add the Aux Jack and have the code handy.  Won't be able to try it for about a week when parts arrive.  Thank You!
Mike
2002 Boxster
CDR220 - Becker 1
Type: 4462
CD: CDP2081
24/99
Mike
Try 5010
Like so many before me ...
Changed the battery only to realize I don't have the radio code for my CDR220 (after the fact) ☹️
Radio: CDR 220
Model: BE 4462
Serial #: Y50 42144
Greatly appreciated
Radio: CDR 220
Model: BE 4462
Serial #: Y50 42144
Greatly appreciated
Try 4356
Loren, your support for folks is nothing short of incredible.
I purchased a car without the code provided, however, the radio is currently working.
The model is a becker CDR-210  with serial number T5005134
With a working radio is the code available via some interrogation?
Kurt
  • Like 1
Kurt
Try 0626
1 hour ago, ROOSTER77 said:
Hi there, hope you can help with my radio code for a CR22. Changed the battery today and DOH!
Y5022121
Thanks Loren. ?
1
Try 4172
Hello, and thanks to advence, I lose code,
my radio is Becker CDR 23
And serial is : 25011255
Thanks again.
Edited by neutron57
mistake
Thanks again.
Didn't read the Lost Radio Code FAQ?
"CDR-23 (or later):
These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DMEand can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected."
Sorry, I do not see it, thanks for explain.
Yet my battery has been disconnected and the post write : Porsche Security
Edit :All is ok, I have not connect Bus...
I connect and miraculous, the radio put On, thanks !!
Edited by neutron57
Hello
I am trying to find a code for my 986 S 2000 radio it is
Typ : cdr-32
Model-no : BE 4667
serial-no : X5005333
Thank you
31 minutes ago, Jean-phi said:
Hello
Typ : cdr-32
Model-no : BE 4667
Thank you
Try 2971
Hi Loren,
I'm babysitting my friend's '02 Boxter S and I let the battery go flat...bad babysitter!  Now I need to get the radio back up:
Model: CDR-220  Becker 1
Type: 4462
Serial No.: Y5050493
Any  and all help is appreciated and from what I've been reading today:  You Rock!
Chris
37 minutes ago, clorelli said:
Hi Loren,
Type: 4462
Chris
Try 9034
