7 minutes ago, Rufrob said:
Hello
i need help with a radio code for a used radio I bought. The dealer here in Japan won’t help
Typ: CCR2200
Model No: BE 6626
Serial No: 15000060
EC: 101
Porsche part number 996.645.127.10
any assistances will be greatly appreciated.
Try 0480
45 minutes ago, ascetic996 said:
Hi All -
Looking for a radio code for CDR-220; serial is Y5052653.
Appreciate the assistance in advance.
Try 4343
1 hour ago, Kent Richardson said:
Looking for the code for a CDR-220.
Serial Number: Y5052913
Car VIN
WP0CB29821U662216
Thank you so much in advance!
Try 8516
17 minutes ago, Loren said:
Try 8516
I tried the code three times with no success. The model number is BE 4462 if that helps. Are there any other codes I can try? Thank you for your help.
DId you use the procedure in the Lost Radio Code FAQ to get the correct serial number?
Yes. I used the serial number from the label on the side of the model. Radio was pulled from crashed 2001 S.  So, it is possible the VIN doesn't match the radio.  Radio SN is Y5052913
You can not believe the label.
If the radio has ever been repaired it got a new serial number that is only accessible through the procedure in the Lost Radio Code FAQ. Please check it that way.
Just checked the SN using the method in the FAQ (TP then Becker 1) and the SN shown on screen matches the one on the label. The front panel is a bit loose and so I'm going to try again while pressing the face down. Could it be that the pins aren't connecting correctly? It seems to be reading my inputs fine. Super confused.
Okay if the number I gave you does not work for the displayed serial number then the radio was repaired by a 3rd party (not Becker) and the serial number is unknown. I doubt even Becker can help you. Sorry.
Understood. Just went to go try it again but it seems stuck on “Wait” for over an hour now. I’m going to try and reinstall the CDR-210 that was originally installed. Could you help me with the radio code on my cdr-210? SN is W5021560.
Try 0195
Hello All. and I was sorry Mr.Loren.(sent to a mail to him)
Please help.I lost the code.
CR-2200
BE4466
Ser. 15020429
Thanking you in advance.
Hello
I am trying to find a code for my 986 2002 radio it is
cdr-22
type :4467
ser : 25010305
24/99
CDP2081
Thank you
CR-2200
BE4466
Ser. 15020429
Try 4938
