Hi everyone I'm new to the form as well just got a 2002 Boxster and I have a radio code but is is clearly wrong. Took the radio CDR 220 BE 625 out and this is the serial number 15007892
any suggestions what code to use? Thanks so much I truly would appreciate the help.
Edited by Birgit Miller
Use the procedure in the Lost Radio Code FAQ to verify your serial number. Even the tag can be wrong if the unit was ever repaired.
Use the procedure then report your (internal serial number) here.
5 hours ago, Tom Meloche said:
Hi Loren,
I need a code please.  98 Boxster, CR-210, model # R1996, serial # V5006488.
Tom
Try 2190
Hi Loren,
 I have a 2000 Boxster lost the radio codes. Not sure if this is the right place to post but I’ll try.
Becker1 cdr 220
model 4462
serial # X5029317
Thanks for any help
Edited by Horace Tyndall
14 minutes ago, Horace Tyndall said:
Hi Loren,
Becker1 cdr 220
model 4462
serial # X5029317
Thanks for any help
Try 5418
Looking for radio code on Becker CDR-220 for 1999 986. Serial number 15062232
Any help would be appreciated.
V/R
Chris
San Diego, Ca
Edited by Sawfish
Added radio model #
V/R
Chris
San Diego, Ca
Try 8654
Hello,
I would appreciate the code help on the following:
1997 911 C2
Type: CDR 210
Model: BE 2282
Serial: W5024514
Thank you for your help!
Edited by JoonSu Min
24 minutes ago, JoonSu Min said:
Hello,
1997 911 C2
Type: CDR 210
Model: BE 2282
Serial: W5024514
Try 5362
48 minutes ago, JoonSu Min said:
Hello,
1997 911 C2
Type: CDR 210
Model: BE 2282
Serial: W5024514
24 minutes ago, Loren said:
Try 5362
Thank you! Worked like a charm.
2 hours ago, Vipei2 said:
Can someone help me with a radio code please,
2000 boxster
Type cdr 220
Model 4462
Serial Y5040279
thank you!
Try 6569
I lost the code (PCM, phone, nav) from my Boxster from 2001.
I still have the 2 original codes (nav and pcm) but the owner added a personal code and does not remember it.
What can I do or how to reset.
It is a european car
The serial pcmnumber is PCM: 020100844
1 hour ago, Hans Cruysen said:
I lost the code ( PCM, phone, nav) from my Boxster from 2001.
You did not read the Lost Radio Code FAQ ...
"Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/ OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/ OPC."
I have the 2 codes but the owner added a personal code and this personal code is missing.
From Porsche and in the servicebook are  mentionned the following codes
Navi code : 1581
PCM code: 8212
Is a reset possible?
Navi code : 1581
PCM code: 8212
Not to my knowledge -  unless a Porsche PIWIS is used.
Hi Loren,  really appreciate your doing this for everyone - but now I need help.
Boxster 1998
CR-210
R3297
V5007083
Wish you the best for the Holidays !
Thx, Russ
Boxster 1998
CR-210
R3297
V5007083
Thx, Russ
Try 5439
Wish everyone marry Christmas ?
I need some help for my Navi on my car it's a boxter 2000 mod, and I just but a second hand Navi and I didn't know about the code, so now I'm stuck with nothing in my car... Could u guys pls help?
It's a BE 2580
thanks for answer!
Edited by Hemin Coplanto
