Dears,
this is a treasure!!!
just bought today my first Porsche, a 996.2 c2 coupe.
the car was semi-abandoned as it only has 40k miles, but the previous owner had nothing from the initial documents including the radio code.
i tried three times to put a random one..... and now I only see a “Wait” message.
any ideas please?
it s a CDR22 , type 4467 and s/n 25007897
thank you I’m advance!
christos
7 minutes ago, ChristosP said:
Dears,
any ideas please?
christos
Try 3108
I have a 2002 Boxster. Had to tighten fuel tank fuel gauge. Did not know that I would have to put in code for radio after disconnecting battery. It is a Becky 1 CDR220, SN# 15007270. Does anyone have the code?
Try 4918
What is the trick on the radio when it says wait. When it first came on I tried different codes and I guess it locked. Waited hours, even unhooked battery for hours, still says "wait".
Please read the Lost Radio Code FAQ
I put the key in and left the radio on for over an hour, code screen popped up. The code you gave me worked. Wrote it down on a piece of paper and put it with my registration. Thank you very much! So much security for a CD-ROM player! Oh did I mention, who uses CD-ROM's anymore? Just us old folks that like to listen to 80's songs like "99 Red Balloons"!
25 minutes ago, Beale 911 said:
Please help
Porsche 911 turbo 2002
Becker
Model - BE 2580
Serial - 15096667
You did not read the Lost Radio Code FAQ...
"Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/OPC."
2 hours ago, 1000miles said:
Hi Loren,
Newly aquired 996. ? Could you please help me out?
Becker CDR-210
BE2282
W5020236
Much appreciated!
Try 2641
  • Thanks 1
I need some help, so, I’ve replaced my fuel pump and now that the battery is back on the radio asks for the code
CDR 220
Model BE 4462
Serial # 15085927
thanks!
CDR 220
Model BE 4462
Serial # 15085927
thanks!
Try 7212
Hello,  Added a new toy to my collection, 1997 Boxster base, CR210 and I think the serial number is T5002262.  Thank you in advance.
Try 2469
