1 hour ago, RMC Motorcars said:
Hi I have a 1998 Carrera 993 vin# WP0CA2990WS340852 need the radio code.
Please read the Lost Radio Code FAQ and follow the procedure there. The VIN does nothing for radio code - since changed could have been changed out numerous times.
Hello! Had to disconnect my battery today to do some work to the 2002 986.
Becker CDR-220
Type: 4462
Serial: 250 10 195
Thanks in advance for any help!
Edited by Daviddelpauley
I wanted to include additional information
Becker CDR-220
Type: 4462
Serial: 250 10 195
Try 2313
Hello! Had to disconnect my battery 2000 986, and i lost my radio code, any ideas anyone?
Becker CDR-220
Type: 4467
Serial: 150 03 591
Becker CDR-220
Type: 4467
Serial: 150 03 591
Try 1063
Hello there,
I have a 1999 Boxter Cabriolet and am hoping to get the radio code.  It's a CDR-220 - 4461 Becker 1, and the serial code is: X9016191.  Are you able to help?
Thanks for your time.  ?
13 minutes ago, T L said:
Hello there,
1
Try 0892
Glad I found renntech - I just bought a 2000 Porsche 911 Carrara 2 and the battery was flat.  Bought a new one and all good - except the radio.  After reading this string I see there is hope!
I found this - Becker radio - Model #4362 - Ser# Y5021220.  I'd really appreciate your help getting this working again!
Les
Les
Try 2323
16 hours ago, Loren said:
Try 0892
I appreciate your help, but that one didn't work. ?  Any other ideas?
Did you follow the procedure in the Lost Radio Code FAQ to find your correct serial number?
If not, please do so and re-submit the correct serial number.
If you did follow the procedure then chances are that your radio was repaired by a third party (other than Becker) - in that case, I can not help you.
17 hours ago, Loren said:
Try 0892
I tried again and it worked.  Thanks!
Hi Loren,
Looking for a radio code for the following:
Becker CR 210
Model BE 2182
Serial No V5009123
Thanks in advance.
19 minutes ago, Shdwfx said:
Hi Loren,
Becker CR 210
Model BE 2182
Serial No V5009123
Thanks in advance.
Try 5983
On 10/3/2018 at 4:18 PM, T L said:
Hello there,
Thanks again for this code...  Is there a way to make a donation for your time?
Yes, just click on "Donate" link at the top or bottom of any page.
