1 hour ago, mstaniszewsk said:
Hello,
I changed the battery in my 2002 Boxster and I need a radio code. Please send a code.
CR-220
Becker 1
Type 4362
SerI Y5023782
Try 2354
31 minutes ago, Hybridiia said:
Hi Loren - can you please help me with a code for the following CDR-220...
model: BE6625
serial #: 15000024
thank you
Another radio?  We already did this once.
Try 0192
40 minutes ago, Robert M said:
Hi Loren if you can please help me
out 01 Porsche Boxster
serial# 15031187
cr-220
type 4362
thank you
Try 8474
Try 0192
Thank you Loren! The code worked... and yes, I purchased another ebay radio.
Hello, I lost my PCM codes and my battery went down.
can you help me ?
I tried 0528 but this code is not ok.
Mathieu
can you help me ?
Mathieu
You did not read the Lost Radio Code FAQ...
"Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/OPC."
If possible, can I get some assistance with the radio code for my CDR-220 radio, serial number Y5042657, type 4462, 24/99, car vin WPOCA298XYU627968
Try 4365
