31 minutes ago, Sharq said:
Hi Loren.
Just bought a used 996 '98 - missing radio code.
CDR-220
Type: 4462
Serial: W5002264 or WS002264, not sure S or 5
Porsche in Iceland gave me code: 5106 when I gave them the VIM. It didn't work.
Thanks in advance.
Try 2485
Have a 1999 Boxster with a CR210 radio
model R-3297
Ser# V5009134
can you supply me with an unlock code, I cannot make the one given with the car work
Thanks in advance
model R-3297
Ser# V5009134
Thanks in advance
Try 5971
  • Like 1
1 hour ago, advanceauto said:
Please help me get my CR1 radio code .
SN is POCR-1M0811791
           V10811791
I believe that is a Blaupunkt or Alpine radio and my program only works with Becker/Porsche radios - as stated in the Lost Radio Code FAQ.
I had my battery charged today and they disconnected it. Lost code. 2000 boxster becker 1  type 4462
Serial: y5042544
Cdr-220 need unlock code
Thanks for help!
Edited by John Donaldson
Serial: y5042544
Thanks for help!
Try 9062
I am seeking the radio code to a CDR-220 replacement radio for my 2000 Boxster S.
Model: BE4462.  SN: 15062512 (see attached photo)
Any assistance is greatly appreciated.
Wow - still didn't follow the Lost Radio Code FAQ to "display" your radio serial number. The printed tag will be wrong if the radio has ever been repaired. WHen Becker repairs the radio it gets a new serial number - but does not get a new sticker. Hence the procedure in the Lost Radio Code FAQ to get the current serial number.
Well, I hope your radio has not been repaired and the sticker is correct.
Try 9806
Thanks Loren for your direction & assistance. I did verify the SN which did match the sticker and your code did the trick. Now I need to study the plethora of functions on this radio which far exceed my typical On, Tune, and Off!
Best regards
Will you please help me get the code for the following:
CR-220
Becker
Type: 4362
SN: 15031724
24/99
Thank you!
Josh
Although you have a different radio, I’m sure the process is the same. I posted the same request and received a response from Loren who steered me in the right direction (determining the correct radio serial number) and provided me with a code that unlocked my radio. Not sure how to get you his contact info but there are plenty of his comments in the porsche radio forum so I would search there as well as posting your request. Good luck.
CR-220
Becker
Type: 4362
SN: 15031724
24/99
Thank you!
Josh
Try 8675
My 2002 Boxster needed a new battery...and now I need a radio code (help!)...
CDR - 220
Ser 15009230
type 4462
CDR - 220
Ser 15009230
type 4462
Try 2138
  • Thanks 1
PORSCHE  BECKER  CDR-220  BE6625  /  996.645.126.10    15003747
The factory original radio code for your unit is:  8479
I hope it could be helpfull for someone ?
Regards
