Hi Loren, From the size of this thread - This seems to be a full time job - I appreciate your help and Thank You
1999 996
Becker
CDR 210
Model - BE 2282
Ser # W5025044
Thanks again
Phil
1999 996
Becker
CDR 210
Model - BE 2282
Ser # W5025044
Thanks again
Phil
Try 6507
It has been SO long since I needed to use the radio password.  Don't remember it.  Could someone please help:
Radio Model:  CDR-220
Radio SN:  15063727
Type:  4462
24/99
Radio SN:  15063727
Type:  4462
24/99
Try 8319
  • Like 1
24 minutes ago, Nicholas Verrier said:
Hi, have lost my code card.
Type: CD-R 22
Model: BE 6621
Serial: 25007857
Help would be much appreciated!
Try 9103
Hi guys,
I'm trying to give life again to my Becker BE2580 installed on a Boxster S model year 2001.
On the left side of the radio I've found two labels:
Type IDIS
Model BE 2580
Serial Y5045452
MLFB: 5WK 78003
serial no: P08030118368/03
date: 00112409 SW 5.25
Accept 4 digits from 0 to 9
May you help me?
Thanks and greetings from Italy
Massimo
4 hours ago, Massimo986 said:
Hi guys,
Type IDIS
Model BE 2580
Serial Y5045452
MLFB: 5WK 78003
May you help me?
Massimo
You did not read the Lost Radio Code FAQ ...
"Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/OPC."
2 hours ago, SuperBrad said:
Hi Loren,
I have a CDR-22
Serial number Y5024807
Type 4467
Any help on getting the radio code would be much appreciated!
Try 2858
  • Like 1
