Hi mam my radio is showing off display i tried to remove the battery many times. I take the radio code from the dealer but it is not working. Maybe different  radio was install  in the car vin.now I think the radio is already lock due to multiple code entry. How can i activate the radio again and set the code.i take the radio serial number. See attach picture
many thanks
joemarie
many thanks
joemarie
You did not read the Lost Radio Code FAQ.
If you did then you would see that I need radio model (must be one of the ones listed) and the display serial number.
Sorry, but without those, I can not help you.
Wondering if someone could please help me. Just got my first Boxster, haven't even got to use the radio yet. Needs code
1997 Boxster Base
S/N T5001787
Thank you so much!
Luke
Edited by Loren
removed unneeded VIN
1997 Boxster Base
S/N T5001787
Thank you so much!
Luke
Try 2764
If would appear that your radio has been repaired by someone other than Becker. When this happens the serial number gets reset to an unknown number (Becker has a tool to set the serial numbers).
Unfortunately, when this happens I can not you. Becker would be your only help at this point (or buy a used radio)
Hello,
I first would like to say, pretty awesome and helpful forum. New Porsche (97 Boxster) owner so im still learning about this pretty nice car!
Im having trouble finding the code for the radio (battery was dead and no owners manual). I hope someone can assist. Heres the info i got off the radio:
CR-210
R3297
Serial: V5007875
Thanks so much!
1 hour ago, zell9999 said:
Hello,
CR-210
R3297
Serial: V5007875
Thanks so much!
Try 2832
