Hi, just replaced battery in my 98 boxster but now radio asking for a code. It's a cdr210, Becker r3297 serial 208012515382076235. Any help would so greatly appreciated. Thanks in advance !
On 8/17/2017 at 4:01 AM, lukecufc said:
Hi I could really do with some help after no radio for 2 months!
Type: cdr22
model no.: be6621
seriel number: 15005215
thank you very much in advance
Try 4858
That is the longest serial number I have ever seen on a Becker/Porsche radio - I hope it is correct.
Try 4828
Loren, thanks for your quick response. I put the code 4828 in and clicked the down arrow and now it is just displaying a WAIT message. Does that tell you anything? To confirm, I got the serial number offf the back of the faceplate. Is this the correct place to look?
I really aprecciate your help with this
Seems like the radio now won't say anything besides "wait". I don't mind waiting but wondering which direction this is goin in...
Thank you, Loren. I apologize for the rookie mistake! Read it the first time but not far enough, my bad...
Once the "wait" is over I will re-attempt this procedure. Thanks again for your assistance
5 hours ago, Will.Escobar said:
Had battery replaced and need stereo code.
its a CDR220 SN Y5024512.
any help would be appreciated.
Try 5346
Hi Loren. Ok I think I have it right this time. CDR 210 , 98 boxster, Becker, serial V5015015. Fingers crossed !
Thank you
Thank you
Try 5275
That did it. You are great, sir! And lightning fast too. PM me if you would like some compensation for the help.
igor
Need help with a lost code.
Model - 6624
ser# - 15004332
On a side note, I have an  02 S with the Bose stereo and the CR220 is not working but we swapped it out with a CDR220 and now no sound comes out. Are they not compatible?
Boxster S that is
Model - 6624
ser# - 15004332
Boxster S that is
Try 3153
Hi Loren,
if it's not too much trouble can you check my radio code please?
1998 911 cab C4
It's a CDR210
R3297
V5016027
thanks Loren
20 minutes ago, Hibbsy7 said:
Hi Loren,
1998 911 cab C4
It's a CDR210
R3297
V5016027
thanks Loren
Try 5181
  • Like 1
Had to replace my fuel sender unit so the battery had to be disconnected. Of coarse code is nowhere to be found.
Type 4462
serial number x5016156
Type 4462
Try 0612
Hi Loren,
I have a 2000 boxster that needed the airbag/horn bushings beefed up which is now great but radio codes lost.
It's a type 4462 ser# Y5039259  24/99.
Hoping you can help.
Terre
3 hours ago, TURBOKING7622 said:
Hi Loren,
Terre
Try 1370
