Hello!
First of all, thank you for this service.
I recently purchased a 996 Carrera (1999) with a CDR-210 and need help retrieving the code.
Model nr.: R3297
Serial nr.: W5020807
Thanks!!
3 hours ago, Strongmomme said:
Hello!
Model nr.: R3297
Thanks!!
Try 7698
Hey I got Porsche Boxster -97 and would be super grateful if you could help me out with Becker code.
Becker cr-21
serial: V5004647
Best Regards!
Becker cr-21
serial: V5004647
Best Regards!
Try 0825
2 hours ago, Loren said:
Try 0825
Ty for your help, it opened up but I don't have any sound, so Im sitting in a struggle with it....
Hi Loren,
I sent you a second request for help on May 13 and you replied what happened to the first request? I went  back and edited that second request to you stating that I had accidentally  sent you the serial number with one character missing. Please help with radio code as I finally got the fuel sending unit fixed and would like to be able to listen to some tunes while out playing.
Thank you
Bill
Type 4462
24/99
Serial 15009249
gal 1 00
4 hours ago, bbrundle said:
Hi Loren,
Thank you
Bill
Type 4462
24/99
Serial 15009249
gal 1 00
Try 1290
Hello Loren,
Thank you so much for this service!
Here's what I have:
CDR24
Model No. BE 6645
Serial No. B5117466
Any help you can provide is appreciated,
Joanne
11 minutes ago, EuroCarUS said:
Hello Loren,
Here's what I have:
CDR24
Model No. BE 6645
Serial No. B5117466
Joanne
You need to read the Lost Radio Code FAQ.
"CDR-23 (or later):
These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected."
"CDR-23 (or later):
My apologies! Thank you, Loren, for the explanation. I appreciate you taking the time.
On 5/19/2017 at 6:14 PM, Loren said:
Radio codes are specific to each radio.
You need to read the Lost Radio Code FAQ...
Try 4131
Thanks again, Loren. Your radio code worked for me.
Thanks Loren. i'll try it tomorrow.
Good Evening / Night
Same problem with the battery and radio code for a Boxster 2001, here are the informations I have :
24/99
SER : 15004457
Type : 4467
Thank you for your help !
24/99
SER : 15004457
Type : 4467
Try 1432
