On 5/17/2017 at 9:41 AM, Loren said:
Try 4241
Hi Loren,
So, I got my removal keys today and swapped in the cdr220 but the code 4241 didn't work.  So after some thought, I went back and read your 'Read This First' post and went through the Becker 1 serial number retrieval procedure and discovered that the last 3 numbers I gave you were incorrect.  The correct info for the radio is:
Model BE4462
Serial no. X5030954
Hopefully that will generate a code that will work
JP
Edited by JonPaul
Had some wrenching on my '95 968 that required me to pull the battery and of course the CR-1 now needs a code.  Previous owner left the manual in the glove box and sure enough had pulled both the code cards.  :-(   I know the CR-1's can't be decode from the serial number, but I'm here for some help.
Radio model: 993.645.104.00
S/No: POCR-1R0118855 V40118855B
Thanks in advance!
3 hours ago, JonPaul said:
Hi Loren,
Model BE4462
Serial no. X5030954
JP
Try 5043
Thanks in advance!
You need to read the Lost Radio Code FAQ - we can not support that radio.
Hi Loren
wonder if you could provide the radio code for my 2000 Boxster S
Becker 1
type 4467
serial no y5022457
thank you in advance for your help
Nigel
5 hours ago, NigelM said:
Hi Loren
Becker 1
type 4467
serial no y5022457
Nigel
Try 4782
3 hours ago, 1886hi-grade said:
Hi Loren
I am hoping you can help me out with a code for a 1998 993
Becker CDR-210
R2896
VS010589
Thanks in advance....
Chris
Try 4201
 Hey guys, I believe I started a new topic by mistake. I have a 2001 Boxster and had to replace the multifunction switch. I didn't have a radio code so I tried some from this site, alas with no luck. Any help to get me out of the WAIT state and a valid radio code would be greatly appreciated. Thanks.
Becker 1
Type 4462
S/N 15061604
24/99
CD CDP2081
Becker 1
Type 4462
S/N 15061604
24/99
CD CDP2081
Radio codes are specific to each radio.
You need to read the Lost Radio Code FAQ...
Try 4131
Hi Loren,
Yes, I did read the FAQ.  Thought I'd at least try the forum to see if anybody had any luck at all with a CR-1.  I'll try the dealer, but all my research says that they won't help.  Don't know what they do if they had the 968 in the shop for service with the battery pulled for any length of time. Looks like I might be shopping for a replacement radio.
You have a great service for Porsche owners.  Many thanks from all of us!
16 minutes ago, Jeffhsr said:
Just gave it a try...did not work. Any other ideas?
Did you use the Lost Radio Code FAQ procedure to make sure you have the correct serial number?
If not, then please do so and then post the correct serial number.
Sorry...the Serial Number is  V 5011838
Try 6756
If that does not work then your radio has likely been repaired by a third party. In that case only Becker Autosound can help you... sorry.
Hello.
I just bought my first Porsche.. 2002 boxter.  need a radio code if someone would please help
Becker
type 4462
serial 25010436.
2 hours ago, 5diehls said:
Hello.
Becker
type 4462
serial 25010436.
Try 5094
