8 minutes ago, brunofarare said:
Hi Loren
I have a 996 4s with a PCM 1. SN: PO8150120975/01. Just changed the battery and need the two codes. Do you think it's possible?
/Carl
From the Lost Radio Code FAQ...
"Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/OPC."
2 hours ago, zoran996 said:
Hello,
Looking for some help with the radio code for 99, 996. Model 3297 SN V5009550.
Thank you!
Try 1620
Radio code infor for my 1997 Boxster is as follows:
4462
seri# X5032313
48/98
GALI 00
cdp 2081. Any information on the unlock code is greatly appreciated.
Thank you, Kurt
4462
seri# X5032313
48/98
GALI 00
Thank you, Kurt
Try 6461
Just bought my first Boxster (2002) qnd I need to remove the battery to fix a fuel leak. I am the 3rd owner and the security code for the radio is no longer with the car. The radio information is as follows please help me with the codes
Type 4462
24/99
Serial 1500924
THX
Bill
Type 4462
24/99
Serial 1500924
THX
Bill
Try 4803
Hello Guys, need help please. I've changed the Batt on a CDR-220 and now the code is needed.
Type: 4462
24/99
Serial: Y5035943
Type: 4462
24/99
Serial: Y5035943
Try 7340
PLEASE HELP! I recently purchased a 1999 Porsche Boxster from a local small dealership and they didn't reset the radio for me after changing the battery. No number on sticker under the hood.  Any information will help!
SER # W5003053
01/99
Edited by Loscano
SER # W5003053
01/99
Try 9039
Hello Loren, thanks for the code but it did not work, ive try twice, can it be another one?
Type: 4462
24/99
Serial: Y5035943
Kind Regards
Type: 4462
24/99
Serial: Y5035943
Kind Regards
That 7340 code is what the Becker systems says for that serial number... so there is a good chance that someone other than Becker repaired that radio.
Hello loren,
It has been a real pain in the butt since the calculator for the Porsche radio Codes was taken down.
I have searched the internet with out any luck in finding a site with this calculator for Becker or Porsche
I do not suppose I could get you to reveal your source? Here is my customers information:
CDR 220  BE4462 N5002411  2000 Boxster S.
Thank You Loren.
13 minutes ago, porschehawaii said:
Hello loren,
Thank You Loren.
Try 0830
still not working -- I tried 1010 x 2 and then 1011 (bc another post said go up incrementally) ... I have double checked the #'s:
CDR-220
Serial#:  Y5039691
Type: 4462
CDP 2081
24/99
any other suggestions?
CDR-220
Serial#:  Y5039691
Type: 4462
CDP 2081
24/99
At this point you likely will need to contact Becker.
The only radios I have seen like this were repaired by a third party and that third party changed something that causes the code to no longer work (or ir changes the code). Sorry.
Hi all, I have a 2002 Porsche Boxster S with a CDR-220
Type 4462
Serial 15004811
Can you tell me the codes to try?
Jay
