On 10/16/2016 at 8:42 AM, Bryenth said:
Type cr220
model be 6624
serial number 25007842
Try 8983
Please consider a donation to keep this site running.
1 hour ago, omgsickclipz said:
Hey guys i could use some help i just got a 2002 Boxster and the radio is locked?
cdr-220
becker
type-4462
sn-15004263
24/99
Try 9016
Hello there.
Wrong code issue with the PCM of my car -  2002 911 4S
BECKER
TYPE IDIS
Model no BE2580
Serial - 15091998
Is the Siemens serial needed also ?
4 hours ago, mpane7 said:
Hello there.
BECKER
TYPE IDIS
Model no BE2580
Serial - 15091998
You did not read the Lost Radio Code FAQ first.
" Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/OPC".
Hi Loren, it's me again, need a code for a cdr 210
BE2282
V5010892
Thanks in advance, you have been a great help, happy to be a member here
BE2282
V5010892
Try 0963
Code needed - CDR-220  Serial Number Y5046660
Worked like a charm - thank you!
Edited by pc1098s
Hi Loren, I've got a CDR220 BE6625 S/N 25016660 would you pretty please be able to decode this and I promise I'll write it down in my booklet :) **** battery replacement.
Try 0549
