Just now, RustyGasket said:
Hi Loren,
Would you be so kind? Need the code after a dead battery.
CDR 220
Type 4462
Serial # 15062841
24/99
Thanks in advance
Try 6590
Hi Loren.  I would really appreciate your help.  Had the code card so disconnected the radio. Turns out my card isn't for my radio.
Typ: CDR 220
Model-No.: BE 4462
Serial-No.: X5026102
48/98
thank you
Typ: CDR 220
Model-No.: BE 4462
48/98
thank you
Try 9365
8 hours ago, Loren said:
Typ: CDR 220
Model-No.: BE 4462
48/98
thank you
Try 9365
Thank you Loren!  You're a genius, a life-saver and did I mention - you're a genius! :).
Thank you!!!
Hi Loren,   really would appreciate your help mate.    Got an old 2000 911 Carrera and after an engine rebuild nobody can remember the code and cannot locate the card where it was recorded.
Using instructions I found on the net I can say it is a Becker
Model 4367
Serial Y5022093
Any help you can give would be much appreciated
Thank you
Hello Loren,
I wasnt aware i would need a radio code when i changed my battery. My radio screen is going out but it think i managed to get the serial number.
4462
X5030040
48/98
Thanks!!
Model 4367
Serial Y5022093
Thank you
Try 0364
3 hours ago, 4thgendj said:
Hello Loren,
4462
X5030040
48/98
Thanks!!
Try 0320
35 minutes ago, richardm said:
Can you please help me with my radio code
Beker cdr 220
4362
ser # 15004648
24/99
Can any one help.....thank you
Try 0843
5 minutes ago, bmo72 said:
cdr23
model be 6627
serial: 55036243
thank you
Brian
You obviously did not read the Lost Radio Code FAQ - read this first
" CDR-23 (or later):
These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected. "
Hello,
I have the same problem, I wasn't aware of the unlock codes for the radio when I changed the battery.
Becker CDR 220
type BE 4362
serial # 15004648
Thanks for your help :)
22 minutes ago, richardm said:
Hello,
Becker CDR 220
type BE 4362
serial # 15004648
Try 0843
9 minutes ago, richardm said:
the code did not work.....can we try another maybe ....thanks so much anyways
Did you use the procedure in the Lost Radio Code FAQ to get your correct serial number?
If not, please do so and then post again here.
I checked the info
BEKER 1
4362
ser # 15004648
24/99
Vin # WP0CA29902S652809
CODE 3 0843 DID NOT WORK.......THANKYOU SO MUCH FOR THE HELP
2 hours ago, richardm said:
I checked the info
BEKER 1
4362
ser # 15004648
24/99
Sorry, I can not help you then.
2000 Boxster S
CDR-220
type: 4462
Serial: Y5035660
VIN: YU663144
Thank you...
Edited by Jimc23
forgot item
