Hello, I was hoping you could help me recover the code for my 99 Boxster.
Becker 1, type 4462, 24/99, Serial 25013163
Thank you
Try 4318
Thank you
Try 4318
Worked like magic!!! Thank you so much!
Hello,
I am in need of my radio code after battery change. Thank you for any help you can provide!
2002 Boxster
CDR-220
Type 4462
24/99
Ser 15009303
Hello,
2002 Boxster
CDR-220
Type 4462
24/99
Ser 15009303
Try 5306
I need help for my lost PIN code after battery change.
911 996 from 2003
Serial 35013134
Type 6632
Thanks!!
You obviously did not read the Lost Radio Code FAQ first...
"Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/OPC."
