Hello,
New, to me, car.  No radio code unfortunately.  Numbers are:   4462; Y504110
Followed the steps to get these, hopefully you have something for me!  Thanks!
It's a 2000 Boxster BTW
Edited by Vans0603
Hello,
Try 0624
Hello,
Try 0624
Thanks for the quick response, unfortunately those numbers don't work...and I tried it three times. So I'll be waiting for anymore combinations you may think will work. Thanks!
Hello,
Try 0624
If you followed the instructions in the Lost Radio code FAQ and gave me the correct serial number then there is nothing more I can do for you.
If that is the serial number your radio reported then it is likely your radio has been repaired without following the Becker (the radio manufacturer's) procedures.
Hi guys,
I'm new here and my radio doesn't work after a battery change.
My serial nr is Y5025469 and it displays Becker 1 and "Type 4467" after having pressed the TP-button for 10 secs as described here.
Thanks for your kind help with this.
//Robert
Hi guys,
//Robert
Try 1328
Gre
Hi guys,
//Robert
Try 1328
Great - many thanks it worked perfect!
BRs,
//Robert
Same boat here. New (to me) 2002 Boxster S
Becker 1
Type 4362
Ser. 15004314
Thanks!!
Try 3109
Thanks for such a quick reply and a great help! It worked. My daughter is much happier now...
Loren,
I'm another lost sheep and new to the forum.  I have seen that you have been able to help others.  Any help here would be greatly appreciated.
I have lost the radio code card for my 2002 Boxster
The Becker Model is 4362
24/99
Ser # 15001348
Loren,
24/99
Ser # 15001348
Try 0516
Hello, 2000 Boxster S
CDR-220
4462 24/99
Serial Number Y5043158
I tried to match my serial number to something on the board but no luck..
Any suggestions ?
CDR-220
4462 24/99
Any suggestions ?
Try 4278
Loren,
24/99
Ser # 15001348
Try 0516
You are awesome! Thank You..........
Hello,
Try 0624
Well thanks Loren, I'm not sure about anything being repaired, as I bought the car a couple days ago, the dealer said they didn't have a code, I googled codes, and I found this site. So after the wait period is over, I will try to get those codes again to double check, but idk. Thanks though!
Hello,
Try 0624
Alright...so the waiting period ended, tried again to no avail. Decided to double check instructions. I'm sorry, but the serial is actually Y5041100, with the 4462. I'm sorry I didn't put the second zero originally. I hope this is the reason the code you originally gave me isn't working :) thank you again! I have enjoyed very much the sound of the engine lately...
Hello,
Try 0624
For that serial number try 4194
