Sorry. I did read the FAQ but I missed that. What options do I have then?
"Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/OPC."
Wow!
Loren is still helping people out with this.
My last 996 needed a code, and now my new 996 also needs a code.
Appreciate if you can help
Becker CR220
Model - 4462
Serial - 25016202
Thanks in advance!
Wow!
Becker CR220
Model - 4462
Serial - 25016202
Thanks in advance!
Try 0980
Purchased car at auction...of course some idiot did not include manual or codes!
Becker 1
cdr 220
type 4462
Serial # 15007403
then it shows 24/99 but not sure if that helps
Becker 1
cdr 220
type 4462
Serial # 15007403
Try 3151
Hello and I was hoping you could help me in finding my Radio Code.
Becker 1
4462
Y5039642
Thanks for your help on this.
Becker 1
4462
Y5039642
Try 5940
Becker 1
4462
Y5039642
Try 5940
Loren -
Did you ever have one of those days when you just knew everything you did just turned out perfect?   Today was just one of the those days for me and you capped it off!   I just knew when I got the code from you it would work and sure enough, it did.
Thanks for all your help.  I truly appreciate it !!
Cary
Hello.
  I  acquired a 2000 Porsche 911 C4 with a weak battery. Please provide the radio code so I can replace the battery and use the radio.
Becker CDR-220
Type:  4462
Serial #:  Y5038395
Many Thanks
Hello.
Becker CDR-220
Type:  4462
Serial #:  Y5038395
Many Thanks
Try 3401
Hello.
Becker CDR-220
Type:  4462
Serial #:  Y5038395
Many Thanks
