Hello, after 6 years I've decided to go back to my OEM.... And of course I can't find the code for:
220
Becker 1
Type 4462
S/N: Y5040812
-Ernie
Edited by elchivo21
220
Becker 1
Type 4462
S/N: Y5040812
-Ernie
Try 6738
I really hope you can help me out with my radio code.
Here is the info:
Vehicle VIN:  WP0CA2987WU625723
Radio:
CDR-210
R3297
W5021293
Please let me know if there is anything else you would need to find the code! THANKS!
Here is the info:
Radio:
CDR-210
R3297
W5021293
Try 6491
Here is the info:
Radio:
CDR-210
R3297
W5021293
Try 6491
Just tried, no luck...
Here is the info:
Radio:
CDR-210
R3297
W5021293
Try 6491
Did you follow the procedure in the Lost Radio FAQ to get your correct serial number?
Here is the info:
Radio:
CDR-210
R3297
W5021293
Try 6491
I did not know about the FAQ, I will read through it now.
Thanks again for your effort,  I really appreciate it.
Hi! New Boxster owner here without radio code.
Becker CDR-220 Type 4462 and serial number is 15046138
Many thanks in advance! :)
Try 9653
I have the serial number... and thanks to everyone, a lot of suggested codes. But if someone has the ones to try: Serial #X5024524...
1999 Boxster... with a new battery!
Many thanks
Many thanks
Is that you full serial number... please read the Lost Radio Code FAQ - then respond here.
Hi Loren, I have a CDR-220, type 4462, serial number X5033081. Thanks in advance!
Try 1078
That worked, thanks again!
Hi Loren,
CDR-220 type 4462
Serial number is X5016655
Thank you very much
Try 9694
Thank you Loren, it worked perfect! Appreciate it a lot.
I followed the Lost Radio Code FAQ procedure and my Becker CDR220 info is:
Type 4462 / Serial number 5024524
Many thanks in advance... !
