Just had some repair work done on my 2001 996 C4 they disconnected the battery. Searched all the paperwork I had on the car and no code. I was hoping for some help. Please and many Thanks.
BE4462
15086281 24/99
BE4462
15086281 24/99
Try 8780
Need radio code 1999 Boxster radio serial number W5011217. Becker 1 type 4462. Disconnected battery to replace now radio needs code. Thank you
Try 2309
Hello, new to the forum and hope you can help. Need radio code for Becker CDR 220. Model 4462 serial; X5021438. Thanks in advance.
Greetings,  a code card didn't come with my car when I bought it and since I replaced the battery recently I can't get the code from anywhere else.  Dealers want $250 to "take out the radio and get the SN, then call Germany"
Well, I knew there had to be other options.
Here is my information, if someone could help me out that would be very much appreciated.
my SN should be X5033455 ..
If this isn't the correct one then I really don't know what else to do.  I've followed all of the directions listed in previous posts to this thread.
I also got this number CDP2081 as well as 48/98, But I don't really know what those are.
Again, thank you very much for the help.
Cheers!
Thom
Cheers!
Thom
Please READ the Lost Radio Code FAQ -- and follow the instruction to get your serial number and include the model of your radio here.
Whats up guys? I have a CDR-220 4462 SN# X5023591. I'm in need of the code to get it working again. Any help is appreciated. Thank You.
Edited by Type 3 TJ
Try 1063
THANK YOU!!!!!
Cheers!
Thom
my serial is x5021688
type 4467
24/99
pşease can anyone help me for the code
thank you so much
Cheers!
Thom
Thank you for the response,  I have read the provided link, that is how I ended up on this thread instead of the numerous other threads here on this board.  However,  maybe I am not calling the numbers I get what they are on the FAQ  As above,  I got the DCP2081, then came up SN#X5033455, I turned it again and came up the 48/98.  So, since I am at work, when I get home, I will perform the procedure again to see if these numbers still come up as the same information.
If indeed, I did it right and you can help with this, I'd appreciate it.
If I screwed it up AGAIN, then I will try one more time.  If that doesn't work perhaps I'll just wear headphones all the time.
Thank you.
Edited by Thom Maxwell
