Thanks in advance Loren. Have a 2002 Twin turbo that hasn't been running for a while and need code for my CDR 220
can you please help me out.
Model # BE 6625
Serial # 15005796
thanks again!
Try 9095
Model # BE 6625
Serial # 15005796
thanks again!
Try 9095
Thanks Loren, I will try it out.
Thanks in advance to you, Loren. My alternator died and now I need the code for my CDR 220
Model -- BE 6625
Serial -- 25015580
Thank you for doing this!
Model -- BE 6625
Serial -- 25015580
Try 9284
Well having just purchased a 2002 Boxster S to modify a bit, the first thing I did was search the internet for forums to join.
My first find was thing one and the first thread I noticed potentially has an answer to my first problem - a locked stereo!
Loren, if you can help it will be really appreciated by this new member!
CDR22
model - BE 4467
serial - Y5029296
Thank you in advance!
CDR22
model - BE 4467
serial - Y5029296
Try 5250
Just purchased a 996. Radio locked. Thanks to your forum, I was able to retrieve the following info:
CDR 220
Becker 1
4462
X5025990
48/98
Appreciate any assistance with the code.
Edited by GRUS
CDR 220
Becker 1
4462
X5025990
48/98
Try 1301
For some reason the "wait" display doesnt go away after 30 min or longer now. I had tried a couple of codes prior to posting. I hope I didnt permanently lock it.
Please READ and follow the procedure in the Lost Radio code FAQ for your exact radio model.
Just replaced radio in our 996.  Need help with code please!
Type BE 4462
Serial 15063614
Tried googling for a calculator and can't seem to find one.
Loren,
Thank you for the very quick response. The code worked! I am so thankful to find your forum and highly recommend it to any new owner!
Just got my 996 back yesterday after an engine replacement.  Unfortunatly they disconnected the battery and now no more tunes.  The engine is nice to listen to finally so not that upset. :-)
Model: BE4362
Serial: W5010328
Many thanks!
Type BE 4462
Serial 15063614
Try 0247
Model: BE4362
Serial: W5010328
Many thanks!
Try 0546
Type BE 4462
Serial 15063614
Try 0247
That worked, unfortunately, I learned one of the knobs on the new unit isn't working..the wifey will test it out and see how annoying a partially working tuner knob is.  I may be back if we swap it out!
Thanks again.
Hello Just replaced my battery on 2001 Boxster.
Type: 4462
Serial: Y5060728
Tried several codes already from this forum. Took a super long time to get the "WAIT" to go away.
Please help :)
Type: 4462
Serial: Y5060728
Please help :)
Try 2482
Hi, just bought a 996 c2 and can't find codes. Asked previous owner and they don't know either. Type: 4367. Serial: x5014127 would be very much appreciated if you could help. Cheers
