I've got a 2001 Boxster S with a new battery and no radio code! Is it possible to get a code? It's a CDR 220 serial # Y5024086
Thanks for the help.
LOUIS
LOUIS
Try 9213
Loren
I'm replying to Lost Radio Code and lookup. I have a 1999 carrera4 cabriolet.
I did the TP for 10 seconds drill and the display was exactly as follows:
type 4362
serial X 50 1086 1
I would greatly appreciate a shot at the code. Thanks, awesome thread. So much nonsense misinformation out there.
Chris
Loren
type 4362
serial X 50 1086 1
Chris
Try 0715
It works. Nice, Loren. Are you using machine learning techniques for this? I'm pretty impressed with both how useful your thread is ( look how many people use it and for how long!!) and how nobody else helps us with such a common problem. I hope the reply system is at least partly automated, or you are like some kind of a decoder saint. Thanks, very cool.
Sorry, no automation just me looking up each serial number.
Howdy - May I have your help with an unlock code?
CCR - 220
Model # BE 4462
Serial # 15089160
EC: 116
Thank you!
Try 9763
Thank you Loren, I really appreciate the help. Silver has been sitting in the shed until I got the radio up again!
Yikes, I hope someone can help,
I have  97 Boxster, battery gave up.  When replaced I lost the radio-- help.
Model: CDR 210
R2896  V5005594
thanks.
Try 9396
Worked perfectly, tunes are back, thanks !
radio code, please: serial number:BE662775067674
thank you, kindly
Please READ the Lost Radio code FAQ
"Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/OPC."
Hi Loren,  could you find the code for CDR220 Y5038702.  I have 0194 written into my owner's manual but that doesn't work.
Try 0195
That worked!  Thanks so much.  I just replaced my door latch using the DIY on this site. Now everything is working again!
I just brought home beautiful 1999 Porsche 911 and found out that code card in the car belongs to different serial number.
Loren, can you please generate code for CR-220 type 4362 serial number Y5022539 ? Thanks in advance!
Try 9032
Try 9032
Thanks a lot! Will try when "Wait" goes away.
