Lost code 2002 boxster CDR-220
Seri 1500 7001
Try 2109
unfortunately the code did not work, did it 3 times in a row 3 separate occasions:/ Edited by TheRedFox
Seri 1500 7001
Try 2109
Did you follow the procedure in the Lost Radio Code FAQ?
If not, please do so and re-post the correct serial number here.
hi battery died and didn't now I needed a radio code.
cdr220
be4462
x5028758
thanks in advanced for any help
Try 1457
worked awesome thank you so much
Loren,
I have 1998 boxster , battery disconnect and lost radio code
Becker CR210
R1097
Vso11994
V1014218
Can you suggest a code?
thanks
Shd be V5011994
r1097
Try 8757
Please help retrieve radio code! Thanks! =)
Boxster 2002
Becker 1
type 4462
ser 15001979
24/99
Gal1 00
aux on
Cd cdp2081
Try 5053
need help lost code
the radio
model BE 2580
SERIAL 15058912
JOSE
Well, you obviously did not read the Lost Radio Code FAQ.
If you did you would have read:
"Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/OPC."
Help! Lost radio code:
1999 996 Cab
Model: 4462
Serial: X5028711
Thanks much for any help.
Try 1081
Excellent! That worked perfectly. Thanks for the quick response.
