Kind Sir:
I need the code for the following so I can put it my 928:
CDR-220 Model No. BE6625
Serial No. 25010468
Previous owner stated it came from a 2002 c4s.
I can provide a VIN if needed.
Thank you so much for your help.
Thanks in advance.
Kind Sir:
Serial No. 25010468
Thanks in advance.
Try 9834
Good evening,
Thank you so much for doing what you do.  I'm trying to get my father's 2000 Boxster back on the road for him.  I replaced the battery and now the radio is next.
Becker CR-220
Type 4362
s/n Y5022185
Thanks again,
White944
Good evening,
Becker CR-220
Type 4362
s/n Y5022185
Thanks again,
White944
Try 8268
That worked like a champ.  Thank you so much.  hope I can repay the favor someday.
If you would like to see this site continue then please consider a donation.
The operating costs of this site are in the thousands of dollars per year and every donation helps... thanks
Hello. Proud owner of a 1998 986 with only 23700 miles. Great car and great experience purchasing it, except the dealer lost all of the books. Got new ones coming from eBay, but need the radio code. If I followed the thread correctly this is where someone can help me, which appears to be Loren, so thank you in advance!
Becker CDR-210 serial number WSO19200
Thank you!
Thank you!
Please check the serial number using the Lost Radio Code FAQ - then re-post it here.
The one you listed here looks too short.
Loren, thank you for the quick response.  I did follow the steps.  I have attached a picture.  When I got into the menu I used the channel up button and scrolled to SN page.  I then used the button under the right arrow key and WSO19200 is displayed.  I was hesitant to push the * or AS or | buttons (you will see those on the picture) perhaps those expand on the number?  Also perhaps it is W5019200?
post-102456-0-53521800-1435845299_thumb.
Try 1084
Hi Loren,
Hoping for some help finding the code for my CDR-210, s/n W5019124.
Thanks in advance, really appreciate the help!
Hi Loren,
Try 5891
Lost radio code. I have changed the battery in my '99 Porsche 911 & the radio is locked
CR-210
Serial # W5011579
Can you please help?
CR-210
Serial # W5011579
Try 0347
