Loren, I can't believe this is page 463 of this thread. Im trying to imagine how many folks you have helped with lost radio codes. I hope you have time for one more. I have a '99 Boxster that did  not have a manual when I acquired it.
The radio model # 4462
Serial# Y5043294
If you could help I would sure appreciate it. Thanks for all you do on this forum!
Try 2535
I went back and accessed the numbers from the display of the radio itself. The Serial number came back the same: V5007740 but the Model number came back as R 2896.
Does that make a difference? The model number I gave you before was 2282 (from the sticker).
Thanks again.
If you get the same serial number then I can not help you - sorry.
Hey Loren,
I've got a serial Y5039253 CDR220 type 4462 radio for a 2001 Porsche Boxter.
Looking for the code
Thanks so much for your help!
Try 1432
You are awesome, worked like a charm! Thanks again
Hi Loren:
I've got a CDR 220 (model BE 4462) with S/N Y5060856. What would be the code for this unit?
Thanks much!
Boxster 1997
CR-220
Type 4462   -  Serial 15086206
24/99
Thank you!
Try 1012
Works perfectly, thank you that service and what a fast answer!
Need radio code for ser#15004005.  Thank you.  Model CDR-220
Edited by rubeng
