hi loren
lost my code and replaced battery so no more sound without code :(
can you recover maybe?
tried the VIN number but it apears this unit has been a replacement so no luck
2000 911/996 C2 convertible
Typ: IDIS
Model no: 2580
serial no:  15076164
thx in advance
cheers
sybe
hi loren
Typ: IDIS
Model no: 2580
serial no:  15076164
thx in advance
cheers
sybe
Please read the Lost Radio Code FAQ
"Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/OPC."
Have a 1999 Boxster. Had to replace the battery the other day. Need the unlock code for the CDR-220. The serial# is X5017740.
Try 0109
Tried it, but it did not work. Entered the code and then the asterisks just came back. Is there a button that needs to be pressed after entering the code (the manual does not say so)?
Thanks for helping!
No, just entering the code should start the radio working on a CDR-220.
Did you use the procedure in the Lost Radio Code FAQ to get your serial number?
If not, then please read that and follow the procedure and re-post the correct serial number here.
Hi Loren. Yes, we did use the procedure from the FAQ to get the serial number. Thanks for the help.
See below:
Loren,
Any additional thoughts?
Edited by BobSC
Try 0109
Thanks for helping!
See below:
Loren,
That (0109) is the code for that serial number. Perhaps your unit has been repaired or otherwise altered. Sorry.
1997 porsche Boxster
Becker
Cdr-210
V5009033
Thank you
Try 1579
hi,loren,sorry it did not work.thank you
Worked like a charm...many thanks.
My Porsche dealer provided 2 codes that did not work and you solved it!
I locked mine after replacing the battery and don't have the code.  It's cor a ccr 220 on a boxster.  The type is 4362 and the model is 15000067.  Can someone help?
Try 4120
code needed as a result of battery change:
BE4467
250 10 169 24/99
many thanks
Adrian
Try 8520
it worked.
Many, many thanks.
Adrian.
Hi Loren, I have just joined the community and brought home a 2002 Boxster S. The dealer I got the car from replaced the battery and now the radio is locked and says wait.
Here is the serial # 25014946
CDR 220.
Thank you!
Sean
Edited by sareisig
Hi loren, I need a code for Becker model: be2582 serial: y5007595 thanks in advance.
Update MLFB: 5wk 78004 serial: PO8040107703/03
Edited by Darinchs123
CDR 220.
Thank you!
Sean
Try 2139
CDR 220.
Thank you!
Sean
Thank you so much Loren! Quick response, saved me $ and time. Much appreciated. Sean
