Hey, I have the same problem.
Type 4467
Seria: W50OA A6
Sorry, that is not a valid serial number (of the radio).
Please use the Lost Radio Code FAQ to get the procedure to get the correct serial number - then re-post here.
I used the same procedure, and it said "Serial W50O A6". I will check again though. Maybe I misread. I have the CDR-22 Edited by Ashtia9
Thank you for your response, but the display says "Code" (and i can input any 4 digits), so I should go to the service shop?
Yes, the CDR-23 radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS.
1998 Porsche Boxster S
CDR-210
SN: V5009119
I got the SN off the radio screen, I can't really tell if its V5 or VS. Any help will be much appreciated.
Edited by lnb3697
CDR-210
SN: V5009119
Try 5851
Hello
Replaced my battery in my 2002 Carrera and now find myself without a radio code card to unlock the radio....
Becker
CR220
Model Number 4362
Ser # 15001133
Any help here would be very very appreciated.
JTR
Hello
Becker
CR220
Model Number 4362
Ser # 15001133
JTR
Try 5458
Loren,
I have 1997 boxster , battery disconnect and lost radio code
Becker  CR210
Model BE 2192
Radio Serial # U5005105 (looks like that)
Can you suggest a code?
thanks
D
Loren,
Becker  CR210
Model BE 2192
thanks
D
Try 9579
Loren,
Becker  CR210
Model BE 2192
thanks
D
Try 9579
Tried that code, doesn't work, any other options?
D
Loren,
Becker  CR210
Model BE 2192
thanks
D
Try 9579
D
Did you follow the procedure in the Lost Radio Code FAQ?
If not, please do so and then re-submit the correct serial number.
Loren,
Becker  CR210
Model BE 2192
thanks
D
Try 9579
D
Radio is out of the car, number came off the deck.
Guess next step is call Porsche and see if they can recover the code or
reset with a new code?
D
Loren,
Becker  CR210
Model BE 2192
thanks
D
Try 9579
D
D
They can not reset it and they will likely charge you find the serial number and code.
Why not put it back in the car (briefly) to get teh displayed serial number - then I can get the code for you.
Loren,
Becker  CR210
Model BE 2192
thanks
D
Try 9579
D
D
Will do and get back to you.
D
