Good afternoon!
I replaced the battery on my '99 911 and, of course, the radio requires the code.  I've got the serial number and model # listed below.  Someone help, please!
Becker CDR-220
Serial #:  X5024699
Model #:  4462
Please let me know if other information is required. Thank you!
Edited by BH911owner
Good afternoon!
Becker CDR-220
Serial #:  X5024699
Model #:  4462
Try 4825
Most of the posts here are not very recent but Ill give her a try. Just picked up a new boxster project and naturally the radio is asking for its code. Ser # is X5027763. Any help would be greatly appreciated. Thanks in advance
Radio model please?
Hello, I'm the fourth owner of my 2002 Boxster. I disconnected the battery for maintenance. I don't have the radio code in the paperwork that came with the car. Its a Becker 1, Type 4462, Serial 15004138 24/99. Hope you can help. Thank you, Patrick
Try 0848
Try 0848
Hello, it worked! Thank you, Patrick
I too have disconnected the battery on my 1999 porsche boxter,
The serial # is X5013967   CR 220
type 4362
and don't know what the 47/98 is or if you need it.
thanks
Good afternoon!
Becker CDR-220
Serial #:  X5024699
Model #:  4462
That code worked.  Thank you so much, Loren!
Steve
type 4362
thanks
Try 1093
Sorry, stupid question - are these the correct steps to get the serial number for the radio? This is for a CDR23
  • Turn off radio.
  • Hold down the TP button for at least 10 seconds.
  • Turn the radio on. "Becker 1" will be displayed.
  • Rotate the right knob slowly, as it will display the Becker model number.
  • Rotate again and radio serial number will display on radio display.
-Josh
  • Turn off radio.
-Josh
Please read the Lost Radio Code FAQ
"CDR-23 (or later):
These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected."
  • Turn off radio.
-Josh
"CDR-23 (or later):
Sorry about that...thanks Loren!
Hello Loren.
I bought my 996 with the complete set of papers. Including the PCM radio card from Becker. Now I have changed the battery and the PCM will have the radio code. OK, I have a look on the Becker radio card but only the model and the serial number is on it.
No code, OK, I called the Porsche dealer and he told me the code. It was the origin code but my seller told me the PCM was changed and the new code was not updated in the data set from Porsche dealer.
Now I have the Becker data and hope you can generate the code.
Here the data:
Porsche 911 996 Carrera 4
HSN/TSN 0583/461
Day of first licence plate:  28.06.2001
VIN: WP0ZZZ99Z1S644531
Becker Ident card data:
Model. CDC-3
Serial No. 11090316
Many thanks for your support.
Cheers
Oliver
Hello Loren.
Here the data:
HSN/TSN 0583/461
Model. CDC-3
Serial No. 11090316
Cheers
Oliver
"Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/OPC."
Help please: bought 1999 Boxster  with dead battery and of course no radio codes.  Followed the directions that were posted and retrieved the Becker radio
serial number X5023652....
CDR 220
any help you can give is appreciated. Thank you in advance....Great site
Edited by JEB
Help please: bought 1999 Boxster  with dead battery and of course no radio codes.  Followed the directions that were posted and retrieved the Becker radio serial number X5023652....any help you can give is appreciated. Thank you in advance....
Try 4135
