Hi, I have a Boxster with a CDR-210 radio/cd player model number R2896 serial number V5007975
Please advise with radio code.  thanks!
Try 7216
Try 7216
Loren, I tried 7216 as well as 7214 and 7218.  any other suggestions?
Try 7216
Did you follow the procedure in the Lost Radio Code FAQ?
Hello Loren
I need the code for my 996 with the CDR 220
model number is 4462
serial number is y5034744
I would appreciate if you can help me out.
Thanks in advance.
Try 8769
Hello Loren
Thanks in advance.
Try 8769
Perfect
Thank you so much
Hi Loren,
Just got a 99 996 and I'm in need of a radio code if you would be so kind to help me out.
Becker cr 220
Type 4362
Ser #W5002465
Thanks in advance for the help!
Eddie
Hi Loren,
Becker cr 220
Type 4362
Ser #W5002465
Eddie
Try 4846
Hi Loren,
   Thank you so much for the fast response.  Last night when I tried it I transposed the numbers and entered 4648 and it went into the long lock mode.  I guess the PO must have tried the code noted in the manual, which didn't work for me either of course.  Now its just a waiting game.
Thanks again.
Eddie
Hello Loren
I unhooked my battery and the Nav code that is in my book is not the PCM1 code that I have to first enter.  I don't have the first code, but I have the Nav code(I hope its right).  Do the code generators work if you have one of the codes?  I did read the FAQ and it says you can't get the PCM1, but what if I have the Nav code?
My serial is 15010388 I used a generator and got 4610, but that didn't work.  Maybe it is I5010388, I tried that and came up with the same code of 4610.  THanks for any help you can provide.
Hello Loren
Please read the Lost Radio Code FAQ for a list radios we can decode.
"Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/OPC."
I need a code for type 4462 serial # X5036878. I just purchased my 2000 Porsche Boxster and the salesman told me he would get the code for my radio on Monday, but I would like to find it this weekend if possible. Thank You for any help you can offer.
Try 3046
I guess I posted my request in the wrong area.  According to your FAQ's, a Becker CR 210 code can be derived from the serial number.
I recently had my fading battery changed and then realized I can't find the radio code.  I have 1992 968 cabriolet.  My daily driver and now missing my tunes.  I have a Becker CR 210 cassette player.  I think the model is R2095, but I'm not really sure about that number.  The S/N is Y5003159.  Any help with the missing code would be greatly appreciated.
Try 4286
Hi I have the same problem no code for my radio I have tried a couple of numbers that some have suggested but no luck, can anybody help before I phone the Dealership up?
CDR-220
4467
Y5035519 (serial number)
CDR-220
4467
Try 5212
