Thank You for the quick response and all you've been doing here for people like me.
5425 didn't work, tried 5427 didn't either. Should I wait a while and then try something else?
Model 4462
SN y5038860 if you want to double check
Model 4462
Try 9541
Hi Loren, another member in distress.
Becker1
Type: 4462
SER: 15002310
24/99
Help with a code?
JohnnyZ
Try 6437
Thank you sir, I will try it tonight after work
JZ
Hi Loren;
Purchased a 07 turbo with no code info.
   Model  BE 6662
   SN  65035743
Any help would be appreciated.
"Adios"
Hi Loren;
   Model  BE 6662
   SN  65035743
"Adios"
Please read the Lost Radio Code FAQ - "CDR-23 (or later):
These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected."
Hi Admin Loren :)
​you are life sever :)
CR-220
Becker1
GAl:00
24/99
type 4362
ser: 15001783
 my best regards
Edited by uaeroot
jast i can saa WoooooW man
like i saa before you are life sever man
Admin Loren
my kindly regards
and its Work for me perfectly  :)
Edited by uaeroot
W5020822
Thanks in advance for your help.
Jerry
Oh, it is a CR-210 unit
Try 6818
Thanks so much.  That did the trick.
Becker1
Type: 4462
SER: 15002310
24/99
Help with a code?
JohnnyZ
Try 6437
JZ
All good, thanks for your code help!
Hi. I just replaced the battery in my 986 and i do not have the 4 digit security code its a 2000 boxster the radio is a becker 1
type 4462 serial # Y5035874 any help would be greatly appreciated!!!   thanks Scott
Try 3204
