Hi there, I am another hapless soul in need of a code...
Becker 1
CDR22
Type: 4467 (24/99)
serial number: Y5022293
Thanks in advance
Chris
Try 2717
hi, im in the same boat :( changed my battery and cant remember code.
here's my info,
becker CDR 220
type 4462
serial: 15009395
thanks and hoping u can help me :-)
here's my info,
becker CDR 220
type 4462
serial: 15009395
Try 9626
YES that worked!!! don't know how you figure this out, but I am GRATEFUL for your help!!! thank YOU!!! :notworthy:
Becker 1
CDR22
Type: 4467 (24/99)
Thanks in advance
Chris
Try 2717
Thank you Loren!! Worked a charm, you are a true gent!
So smart put my battery inside on charger for winter. (closed the hood)
Here comes spring can't open my hood!
Found solution for that and put battery back now no radio code!
Can you please help me.
Becker c220
Type4462
Ser# X5035726
Thanks in advance
Ps great forum!!
ARIE
Brand new owner of vintage 1999 Boxster and the battery was dead on car lot so lost radio capability.
Type 4362 / Ser. # X50 17445 Thank you in advance.
Try 7071
Becker c220
Type4462
Ser# X5035726
Thanks in advance
Ps great forum!!
ARIE
Loren,
Hard to read a couple digits on this one (see attached photo). A friends 97 Boxster, we had to remove the alternator and disconnected the battery... Help!
Jager
post-67893-0-63024600-1401581701_thumb.j
Loren,
Jager
Did you read the procedure to have it display on the radio in the Lost Radio Code FAQ?
Loren,
Jager
He had the procedure for the 220 and it made no sense for the 210. We continued the work and disconnected the power knowing we could get to the decal on the side of the radio but as you can see a couple digits are hard to read.
If you click on the photo it increases size making it easier to view.
I am guessing the number is W5024388 or W5024888.
Edited by Jager
Loren,
Jager
From the Lost Radio Code FAQ...
"CR-210:
Press tone, then 8 and 0 simultaneously. "Becker" appears. Press station up arrow on right. "PR-VERS" appears. Press one of numbered buttons below display, directly below the LCD arrowheads (try a few). The model number will appear. Press station up arrow on right. "SERIAL N" will appear. Press the numbered button again. The serial number will appear.
Or, if the radio is out of the car the then the serial number is on the label."
Becker c220
Type4462
Ser# X5035726
Thanks in advance
Ps great forum!!
ARIE
Becker c220
Type4462
Ser# X5035726
Thanks in advance
Ps great forum!!
ARIE
Try 4851
Becker c220
Type4462
Ser# X5035726
Thanks in advance
Ps great forum!!
ARIE
Try 4851
Thank you very much Loren
It works
Arie
Had a dead battery in my used 2001 Boxter S with a Becker cdr 220 stereo. Can't find the code written anywhere in the car or on the paperwork.
Found this blog and am crossing my fingers for help retrieving the code.
Model # 4462
Serial # 15061588
Will be forever thankful for any help!
Thank you.
Model # 4462
Serial # 15061588
Thank you.
Try 0419
Loren,
Jager
"CR-210:
So this works after the power was disconnected... Hmm... So we got W5024888.
Model # 4462
Serial # 15061588
Thank you.
Try 0419
Thank you, have to "wait" - as we had tried a different code number prior...
