Hi Loren,
I'm an owner who replaced my battery today but do not have a radio code...
Please help. :)
2002 911 C2 Cab
Becker CDR-220
Type: 4462
Serial #: 25013536
24/99
In advance, thank you very much.
Sincerely,
-Cami
Hi Loren,
Please help. :)
2002 911 C2 Cab
Becker CDR-220
Type: 4462
Serial #: 25013536
24/99
Sincerely,
-Cami
Try 8806
or
8804
Hi Loren,
Please help. :)
2002 911 C2 Cab
Becker CDR-220
Type: 4462
Serial #: 25013536
24/99
Sincerely,
-Cami
Try 8806
or
8804
Tried 8804, 8806 and 8808 No luck
Am on wait...
Yet another second owner with no Radio Code!! Any help would be most appreciated!!
2002
CDR-220
Becker
Type 4462
Ser # 25015173
Thanks!!
Try 0938
or
0936
0938 worked for me! Thanks!
Hi Loren,
Another idiot that let his battery die. I have a 2000 996 c2 cab. The CDR220 radio #'s are 24/99, 4462, Y5042450. Thanks for providing this service!
Hi Loren,
Try 4724
or
4722
Hi Loren,
Try 4724
or
4722
Thanks for the tips on what else to try! 4726 worked.
Need help with the radio code
Boxster S -02
PCM1 OEM
Serial: 5wk76026d
From the FAQ...
Can you give me a code for my PCM?
Sorry, the only place you can get a PCM code is from a dealer/OPC.
becker cdr220
4462
25011012
24/99
looking for the radio code,
if you could help me that would be great. Thanks Dave.
Edited by moxster99
Boxster S -02
PCM1 OEM
Serial: 5wk76026d
From the FAQ...
Opps, thanks for the pointer.
loren, the original # i listed was incorrect. the new #'s are as listed.
cdr220
4462
25011012
24/99
sorry. thanks again for any help.Dave.
Try 9089
or
9087
tried both, unsucessful. :angry: any others?? the original #is 8326
not sure if it matters, but the new radio is from an 02 boxster and its now in my 99 996. thanks again Loren.
on a side note, the card that came with the radio says
serial# BE 6625 1 5003216
code #8326
not sure if this helps
Edited by moxster99
code #8326
Don't trust the card use the readout on the radio (see the FAQ). Lots of older radios were replaced for peeling buttons and the new radio card may not have found its way to the owner. (I had the same thing when my radio was replaced under warranty).
The radios for Boxster and Carrera are the same.
Loren
This spring's start up brought up the dreaded CODE which didn't come w/the 2000 Boxster I got two years ago.
Hope you help me.
thanks
Becker 1
type 4462
seri# Y5041503
Loren
Hope you help me.
thanks
Becker 1
type 4462
seri# Y5041503
Try 8922
or
8920
Loren
Hope you help me.
thanks
Becker 1
type 4462
seri# Y5041503
Try 8922
or
8920
Thanks Loren I'll give it a try!
Loren, what would be my next step, I have tried many different combos of the code #'s you gave me, and nothing works. My dealer is quite a drive away, so is there anyone I can call to get other codes if I give them the proper info?? What will the dealer do differently than you?? Also, would calling becker be an option, will they give codes over the phone. Thank you for all your help again, you are a great guy to have around to help solve all our problems!! Thanks again, Dave.
Either a dealer or Becker should be able to do it over the phone. They might require that you fax them proof of ownership.
Also searching for the a lost radio code. Any help would be greatly appreciated. In fact, I am not even sure how to post this question. Thanks
ser 1 Y5047127
Becker 1
Type 4462
24/99
Cd cdp2081
ser 1 Y5047127
Becker 1
Type 4462
24/99
Cd cdp2081
Try 9373
or
9371
