Hello,
I do not have the radio code for a 1999 Boxster radio - can you help me out?
Data is:
Becker 1
Type 4362
Ser X5017118
47/98
Thank you so much!
Steve
Hello,
Data is:
Becker 1
Type 4362
Ser X5017118
47/98
Thank you so much!
Steve
Try 9303
Posted Yesterday, 11:13 PM
js986, on 21 Aug 2013 - 8:18 PM, said:snapback.png
Hi.
No the 4606 code didnt work. :(
Did you obtain the serial number through the method in the Lost Radio Code FAQ?
If not, please do so and re-submit the correct serial number.
Hi.
Yes I did like it said in the manual.
This is from the display:
CDR 22
4467
W5002435
25/98
CDP2065
Best
Regards
Jonas
Hi.
Hi.
CDR 22
4467
W5002435
25/98
CDP2065
Best
Regards
Jonas
Based on that serial number it should be 4606.
If that does not work you will likely need to contact Becker and pay for their service.
Porsche boxster s 2002Cdr22Model be 6621Serial 25008672Davidcdixon@sky.comPlease help with the codeThanks
Please re-check the serial number as that one comes up as "not valid".
Thanks.
I think the number is goodI photod it before battery was disconnected and photod rear of stereo
Hmm... still says invalid in main program.
Tried an old program and it came up with 9952. This program is not nearly as accurate some you may need to try 2 number or 2 numbers lower - so also 9950 and 9954.
I hope this works for you...
Hi all...
Type 4462
SER: 15063003
24/99
Thank you in advance for any help.
Try 5065
Just got home and tried the code... radio is working now.
Thank you so much for the quick response.
Need some help,just purchased car which has been stored and new battery put in and need radio code please. Becker CDR220 Model 4462 Serial Number 15075676 .
Thanks very much.
Thanks very much.
Try 0867
Popped the battery out to clean the posts because it wouldnt start... its starts now, but no radio.
serial x5024096
4462
48/98
Thanks in advance
serial x5024096
4462
48/98
Thanks in advance
Try 0512
Hi Loren,
I have a Porsche CDR 220 Single CD Player (Becker) in a 996. Serial No 25015047. 4462 came up as well. I would be most grateful if you could provide the radio code.
Thank-you,
Momtaz
Hi Loren,
Thank-you,
Momtaz
Try 6531
