Hello,
I've just replaced the battery of my 2000 PORSCHE BOXSTER and don't have the radio security code...Please HELP!!!!
CDR-220
Becker 1
Type 4462
Serial # Y5039457
24/99
Thanks in advance.
Gonzo.
Hello,
CDR-220
Becker 1
Type 4462
Serial # Y5039457
24/99
Thanks in advance.
Gonzo.
Try 3707
Hello,
CDR-220
Becker 1
Type 4462
Serial # Y5039457
24/99
Thanks in advance.
Gonzo.
Try 3707
It worked!!!!! Thank you so much!!!!! You are a magician...
Loren,
Porsche radio - CDR-220, I have lost the code. Porsche part number: 996.645.126.00
Becker radio - model BE4462
Serial number - 15086190
Thank you for your wonderful service.
Gary Knox
Loren,
Gary Knox
Try 0984
Hi everybody, my 97' Boxster have had battery problems, we replaced the battery and now the radio need a code.....
Please can somebody help me with....Thak you very much in advance for your help...
1997 Boxter
Radio...CR 210
Serial # V5004950
Edited by jmqs62
1997 Boxter
Radio...CR 210
Serial # V5004950
Try 2171
Loren,
I really appreciate this service.
The numbers I got from the CR 220 in my 1999 911
4462
W5011150
48/98
Is that what you need?
Greg
Loren,
4462
W5011150
48/98
Greg
Try 4594
Hi Loren,
Could you please plug this info in & see what code it spits out?
CDR 210
R2595
55001116
Thanks so much!
Brandon
98C4S
Hello Loren,
Just bought a new (to me) salvaged Carrera 911 (already have it running and driving!!!). The battery was dead and now I need the radio code.
CDR - 220
1999 C2 Carrera 911 Cabriolet
Type 4462
Ser # X5016556
Thank you so much!!
Steve
Hello Loren,Just bought a new (to me) salvaged Carrera 911 (already have it running and driving!!!). The battery was dead and now I need the radio code.CDR - 2201999 C2 Carrera 911 CabrioletType 4462Ser # X5016556Thank you so much!!Steve
Try 5318
Hi Loren,
the battery of my 2001 Carrera 4 just died. After replacing it the radio asks me for the radio code. Could you please help me out?
Type: IDIS
Model: BE 2580
Serial nr.: Y5051235
Thank you for your efforts in advance.
Cheers!
Hi Loren,
Type: IDIS
Model: BE 2580
Cheers!
Try 2543
hello there,
Had to change out the battery and now I need the radio code. Can you please help me out?
CDr220
Becker 1
type 4362
ser: W5002372
01/99
thanks
hello there,
CDr220
Becker 1
type 4362
ser: W5002372
01/99
thanks
Try 0518
Hi Loren,
Type: IDIS
Model: BE 2580
Cheers!
Try 2543
Hi Loren,
I tried 2543 (several times) as you said, but this code does not seem to be right. Is there another one to try out?
Hi Loren,
Type: IDIS
Model: BE 2580
Cheers!
Try 2543
Hi Loren,
Did you use the method in the Lost Radio Code FAQ to find your serial number? I suspect not.
Please use that method and post the serial number returned on the display.
Hi Loren,
Type: IDIS
Model: BE 2580
Cheers!
Try 2543
Hi Loren,
You were right. I didn`t know about the FAQ. I guess there will be no way for you to find out the code as I have the PCM fitted. I removed the PCM to read the serial number from the radio.
Hi Loren,
Type: IDIS
Model: BE 2580
Cheers!
Try 2543
Hi Loren,
If it is a PCM unit we can not help you (as it says in the FAQ). You can only get that code from a Porsche dealer.
