Another request for help!
Becker CDR-210
Model no. BE 2282SN T5002183Thanks for the help!!
Try 8252
It works, big thanks!!
I lost my radio code, please help
Becker: CDR-220
Model No: BE4462
Serial: W5002463
Thanks a lot for your help
Becker: CDR-220
Model No: BE4462
Serial: W5002463
Try 4830
Works perfectly, thanks a lot.
Edited by nhat179
Hi Loren,Becker CR-220BE 4362Serial # 15050407Thanks!
Try 4762
Awesome! Worked perfectly. You can't beat the Porsche community. Much thanks.
Hi Loren,
I located a used CDR 210 (from out of a 993) and I'm in need of the code, serial number V5008947 model R2896 ( :eek: I'm guessing it looked like a "5" instead of an "S" after the V) I'm very new here, but been around the "other" sites for quite a few years, whom recommended it here. Really appreciating any help, BTW for the life of me :cursing: , I can't upload a photo/sig.?
Thank You, Andy (1982 early widebody)
Hi Loren,
Try 3732
hello i guest loren can help me out!!!!
i have a :
becker 1
type : 4462
serie number : x5025382
cdp : 2081
48/98
thanks in advance
Try 6947
Hi there. Retrieved my radio serial number per your instructions:
1997 Boxster
Becker CR-210
S/N: V5006178
(possible that the "5" is an "S")
1997 Boxster
Becker CR-210
S/N: V5006178
Try 0798
hi Loren same problem as everyone else battery went completly dead now radio says code on display.
becker cdr-210
serial #v50006100
model #r2896
thank-you
becker cdr-210
serial #v50006100
model #r2896
thank-you
Try 9349
Hi Loren,Same problem. I have a 1999 996. I have to disconnect the negative battery terminal before I install my K&N cold air intake. Been searching for my code and can't find it anywhere. My project's on hold until I get the code, so it's pretty frustrating.
My unit is a CDR-210, model number is R 2896, serial number is T5003117.Thanks in advance.
Try 0376
Hey, thank you SO much for this service!
'97 Boxster
Becker CDR-210
R 2896
Serial # V5009396
I found it! It was 9634, if you were curious. Thanks anyway!
