Hi Loren,Can you help me retrive my radio code?ThanksCR-210SN. V5011249R2896
Try 2655
Thanks JFP in PA for the quick reply. Unfortunately 2655 did not work. I also tried 2653 and 2657 and they did not work. Do you have any other suggestions.
Thanks.
Try 2655
Thanks JFP in PA for the quick reply. Unfortunately 2655 did not work. I also tried 2653 and 2657 and they did not work. Do you have any other suggestions.Thanks.
Recheck your serial number for the radio, the one you posted decodes to 2655.
Try 2655
I just checked it over and everything is correct.CDR-210SN. V5011249R 28962655 does not work. Need help stillThanks.
Try 2655
That serial number still yields the same code, 2655; second choice would be 2555, and third choice would be 2565.Just to be safe, how are you obtaining the radio's serial number and entering the code? According to the manufacturer, it should work like this:"CR-210: Press tone, then hold both the '0' & '8' buttons until the radioname appears. Then scroll to PR-VERSION using the tuning arrow.Now you should be able to retrieve the serial number by selectingthe station preset numbers.- CR/CDR-210, enter code by pushing the signal seek switch"
Try 2655
That is exactly how I got the serial number. However, I have not tried putting in 2555 or 2565. I will try again once it unlocks itself.
Try 2655
I just tried 2555 and it did not work. I then tried 2565 and it is now unlocked. Thanks JFP in PA
Hello Loren,
Yet another second owner with no Radio Code!!.
CDR-220
X5023871
4462
Appreciate the help,
Jeff Cameron
Longwood, Florida
Hello Loren, Yet another second owner with no Radio Code!!. CDR-220X50238714462 Appreciate the help, Jeff CameronLongwood, Florida
Try 7640
THANK YOU. 7640 worked.
Loren, I triple checked the numbers... Are there a couple others I can try?Thanks again.
No luck with 4643... any suggestions? Here's the info again. Thanks. CDR210r3297w5023974
If the code I gave you did not work then your serial number is not correct.Please follow the procedure in the Lost Radio Code FAQ to obtain the correct serial number.
I disconnected the battery and lost my radio function. I don't have the code to reactivate it. I would appreciate if you could supply me the code number. Here are the radio's serial and model numbers.
BECKER: CDR 220
SERIAL NUMBER: X5025732
TYPE: 4462
48/98
Thanks, Pete
BECKER: CDR 220
TYPE: 4462
48/98
Thanks, Pete
Try 4899
Any others I can try? Thanks.
Hello,
hope you can help...
I have extra registered here to request :).
1998 Boxter (986 type).
Becker Type: CR21 ?? (bad to read, look attach)
Model: BE 2180
Serial: V5008578
THX :)
post-88575-0-25085500-1364833862_thumb.j
