How can I lookup the radio code for my 05 996 Turbo S? DO I need the VIN?
Lost Radio Code FAQ
"CDR-23 (or later):These radios do not have a security code - that is, not that the user enters.
These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected."
Hi Loren, I have a 2002 boxster. Type is either 4452 or 4462. There's a dead spot on the screen so can't tell. And the serial number is either 15005753 or 15006753. It also says 24/99. Don't know what that means. It's a cdr-220. You're a lifesaver if you can help me unlock it. THANKS
If the serial is: 15005753 then try 5067
If the serial is: 15006753 then try 4987
Hello, I just bought a 1997 Boxster 986...without a radio code. The Becker radio is a CR-210 with the serial number: BE1996T5002173.
I hope you can help me. Thanks in advance :)
Hello, I just bought a 1997 Boxster 986...without a radio code. The Becker radio is a CR-210 with the serial number: BE1996T5002173.I hope you can help me. Thanks in advance :)
Try 4598
I have a 1999 Carerra Cabriolet that just came back from the shop after not running for about 5 years. I cranked it up and it asked for the code??? Never saw that before? Thanks in advance for your help.
Jed
Loren:
I have a 2001 Carrera C4 with a Becker CDR 220.
It is a type 4362
Serial# Y5025463
Any help with the code is surely appreciated.
Thanks for all you do!
Loren:
It is a type 4362
Serial# Y5025463
Try 2180
