Hope someone can help, had to change battery on bolster, don't have radio code Becker Type4467 Serial numb X5016568 Many thang in anticipation
Try 5414
2002 Boxster S I entered a number that I thought might be the code, tried it several times, but wasn't, now it just says wait. I don't know what the right code is. Should I disconnect the battery again and start over?
model cr 220
type 4362
serial # 15004363
thanks for your help. This is really a cool service.
Hi, I hope someone can help. I just had a new alternator fitted and they disconnected the battery and now I have lost the radio code for my Boxster S. Any help would be appreciated.
Can you please give me the correct code for activation
Becker 1Type 4467# P500698424/99
Thanks in advance
model cr 220
type 4362
serial # 15004363
Try 6985
Thanks in advance
Try 1063
Try 5414
Many thanx worked a treat, excellent & speedy response
model cr 220
type 4362
serial # 15004363
Try 6985
Loren, you rock. I just waited a while with the ignition and radio on and it let me try your code- voila! Thank you again
Thank u for the quick reply and for your time but tried and didnt worked...
Then you likely did not perform the the serial number display (per the FAQ) correctly - or transposed the numbers.
If you want to check I'll rerun your serial number again.
now im clear i did a mistake while givin you the type is cdr 22 and not 220 !!! sorry , and hope you can help me now...thanks man !
If you read the FAQ there is an easy way to show the serial number through the display...
though it was the same , now i saw that it was becker 1 , Type 4467 , serial 25005710,thank you
You need to check and see if it is the same.
This is the third time I have asked you.
i checked it to the display the serial was the same just the type was 4467 not cdr 22 ! so to the display it says type 4467 and serial 25005710
Then 4723 should work.
