Hello, need the radio code for my 1999 911.
cr-210
Serial# V5009180
thanks so much
Nicolas
Please double check your serial number - that serial number does not appear to be valid.
Loren,
Thank you for your reply. here are images of the serial number and some other number that could possible help. Any help is appreciated .
Nicolas
Edited by mooryside
Sorry, still comes up invalid.
Try 9907 (that's what I get when interpolating the numbers around your number).
If that does not work you will likely have to contact Becker.
Please help with a lost Radio code, thank you so much !!
CDR 220
Becker 1
Type: 4462
Ser # Y5034220
24/99
Dan
Good Evening Loren,
Had to change batteries on a 2002 Carrera 4S I bought recently, and of course the radio code card is not with the car anymore.
I have a CR220, Becker 1, Type 4362, Serial #25005799, then a 24/99.
Any thoughts on a suitable code would be greatly appreciated. Thanks.
SeattleC5.
Good Evening Loren,
SeattleC5.
Try 9019
Wow! Worked perfectly. Thank you.
How do you figure the codes out?
Also, when tring to play a CD it says Error after trying to read it. Can these things not play burnt Cd's?
-Andrew
Good Evening Loren,
SeattleC5.
Try 9019
Excellent! Code 9019 was the one. Works like a champ again. Thanks for the help.
Hi Loren,
I just added an iPod aux input to the CR220 in my 2000 996, and I can't find my radio code. (previous owner paid $20 to get it, but I can't find it in his records)
The serial is X5018259. If you could generate the code for me, I would really appreciate it.
Mark
Hi Loren,
Mark
Try 5154
Hi Loren,
Mark
Try 5154
Worked perfectly. Thanks so much, you saved me a lot of trouble.
Ok I'm in the same boat as everyone else, removed battery and forgot about radio code. 2000 Boxster S if it matters.
Becker CDR 220
Serial#: Y5039480
Thanks in advance guys!
-Will
Becker CDR 220
Serial#: Y5039480
-Will
Try 7475
