Thank you so much, just got back from my holiday and tried the code you kindly supplied and got music in the Boxster for the 1st time since purchase!! Sadly, cassette and CD Changer are faulty and the radio is American and only finds odd frequencies, but have some radio channels anyway. Off topic, but can the radio channel search be changed to find odd and even frequencies? Or is this fixed. If it can be done easily, do you know if its something I can do or not.
Thanks again.
JIM
Using the "Country" mode in setup the US/Canada radios can only be set to certain frequencies per the radio owners manual (you can download a copy here)
Fantastic Result!
Thanks again, found the country settings and it was on USA as you thought. I scrolled to Asia and the even numbers appeared as if by magic and my wife can now listen to Coast on 103.2.....
The tune button on the radio is lazy and I think my Radio has had it's day, but much better than nothing.
When she's not in the car, I listen to the Porsche sound but have to keep the other half happy when she drives.
JIM
Lost my code had to unplug battery . Please help if you can
1999 Porcshe Boxster
My info CDR 220
MODEL :BE 4462
SERIAL NO: X5037443
Loren, I have 2000 carrera2 nonturbo that I disconnected battery and need radio code to make it work again. It's becker, type (model) 4462; serial Y5050670 and CDP 2081. Thanks. Walt M.
Try 8543
Thanks Loren. It worked. Walt M.
On another subject, what catagory in your renntech do I use to ask about what the onboard computer on my 2000 carrera2 can be adjusted to do. Owners manual says can be set to automatically lock doors but no mention of daytime running lights. But, dealer says can be adjusted to operate them. Also, you have an article describing how one of your members installed daytime running lights on his car which would imply that the onboard computer can't do it. Which area for 996s would this question be appropriate for me to send to you. Walt M.
Please post your question in the 996 forum - thanks.
DRL are a hardware option for that model year - it is not programmed.
Door locks are easy and can be programmed.
Hi Loren, I am new to this forum (but not to Porsche) can you help me get my stereo code please? My car is a 1997 Boxster, the stereo is a CR 210 and the serial code is VS009671....thanks so much!
Try 9756
