Friends! I am here for same reason. Never worried about it until got my battery disconnected.
This is Becker cdr-220
be 4462
y5046107
Please help!
Thank you
Try 9405
be 4462
y5046107
Please help!
Thank you
Try 9405
and it is back on. thank you much
Help! Just re-installed my OEM CD220
Model: BE 4462
Serial Number: Y5046347
Thank you so much,
Chris
Try 2893
Worked! Thank you again!!!!
Hello,
Just picked up a new-to-me 1998 Boxster.
It has the CDR-210 radio.
The only number I see on the back is:
228012516272186756
Need code please.
Thanks in advance!
Hello,
228012516272186756
Need code please.
Thanks in advance!
Please use the Lost Radio Code FAQ to determine the serial number.
Hello,
228012516272186756
Need code please.
Thanks in advance!
Was able to figure it out with the FAQ, thanks!
Hi all.
2nd owner having problems with the radio code on my 02 boxster after changing the inginition switch.
cdr220
model number 4462
serial number 15007963
Thanks for any help...
Hi all.
cdr220
model number 4462
Try 7120
This is a huge help. The original radio in my 1999 996 was replaced with a CDR 220 so porsche can't help me, or won't.
Model Number: BE4462
SN 15062593
EC 114
Can you help please?
JeffD
996 "Rescue" Porsche
(Saved from the crusher)
Edited by Jeff Diffenderfer
SN 15062593
EC 114
JeffD
Try 0269
Had the battery disconnected for a week waiting for the right ignition switch and I don't have a code for the radio.
CR-220
Type 4362
Ser W5007382
Any help or info on a code to try would be great. Thanks-
CR-220
Type 4362
Ser W5007382
Try 2983
SN 15062593
EC 114
JeffD
Try 0269
Loren!
You are a Wizard! Works perfectly. A million thanks!
Jeff D.
Hello, I would really apreciate it if someone could help me out, my boxster's radio got locked after I replaced the battery so it would be of great help if someone helped me out.
CDR-220
Becker 1
Type 4462
Serial # X5031299
Thank You...
CDR-220
Becker 1
Type 4462
Serial # X5031299
Thank You...
Try 6539
