I'm converting my 2002 996 from gas to electric. I've removed all the legacy gas components and have started to power up the electric-only stuff. Today I had to replace the fuse in the back of the radio, now I need to find the code to unlock.
Here is the manufacture's data:
Becker
Type: 4462
15062753
24/99
Thanks for your help. You can read more about my project here:
http://kurtsprojects.blogspot.com/
Thanks again,
-Kurt
Becker
Type: 4462
15062753
24/99
Thanks again,
-Kurt
Try 2302
Thanks Loren! Worked like a charm. Now I can rock out while working on stuff inside the cockpit!
Thanks again!
-Kurt
Had to unplug the battery to change the starter, now the radio is looking for a key...
Becker CR-220
Model 4462
Serial X5037766
24/99
Becker CR-220
Model 4462
Serial X5037766
24/99
Try 4791
Works like a charm. Thanks.
thanks Loren..I'll give it a try tonight, if radio works then all i have left is the motor !! ha ha
two cracked cylinders, saving my sheckles for l and N and IMS retro.
would you go up in displacememnt or stick with 3.4 ? I'd really like to bump up a littel bit.maybe 3.6.
thoughts?
CD-2 I have several opportunities for the SN, as there are several numbers on it with different info:
Tag on bottom: CD-2; 54A90727F02-A
Tag on top: 50100 R; DP22A01 A; 8903-5JA
Stenciled stamp on chassis: 631228
Merci de avance!
Merci de avance!
Try 2387
or
12326
