Had to reset my window w/battery disconnect...
Can't seem to find my paperwork.
If you please:
CR-220
type: 4362
ser: 15000053
Thanks in advance.
Try 0424
Hi I have -
Type - Cr22
Model no - BE4367
Serial no - X5017916
I've already had codes 3170 and 3159 and neither worked - can some one help?
Try 3160
Hi, my Carrera 4 2001 has same problem as referred to above as disconnected to change Control Box.
CDR-220
Becker 1
Type 4462
Ser # W5008233 (see photo I think as "33" LCD is not clear)
48/98
Please help. Look forward to your response.
CDR-220
Becker 1
Type 4462
48/98
Try 1352
Hi Loren, I have tried 1352, did not work then tried 1351, 1354 and still no good just waiting for reset code to try again. Any other suggestions much appreciated?
If that is your radio serial number ending in 8233 then the code I gave you (1352) should work.
Hi Loren, the original radio card states 233 without the 8, could we try based on this three digits. Thanks again.
No, my program requires the last 4 digits minimum.
You could remove the radio and see what is printed on the serial tag...
Hi Loren, I have misplaced my radio code. Thank you in advance for your help.
CDR-220
BE4362
Serial# 15001846
Try 6820
Thank you soooooooo much it worked like a charm!!!
Hi I have -
Type - Cr22
Model no - BE4367
Try 3160
That worked a treat! Feel a bit daft not trying it now, just wen up in 2's instead ... doh!
Thanks, made my drive to lemans so much more enjoyable :D
CDR 22
1999 Boxster 986
4467
SERI X5012153
4998
if anyone can help me i'd really appreciate it
Try 5428
worked a treat Loren, thank you. nothing worse than driving without music
Cr-220
Type:44(5/6)2
Ser:x(5/6)02(9/8)1(h?)(5/6)
my radio is in a world of hurt. the parenthesis are because I am not sure which number it is. A strip at the bottom of the radio is dead so I cannot tell the difference between 5's and 6's, also 8's and 9's. If need be is there a more sure way to get the serial# without going through the system? Please and thank you
Cr-220
Type:44(5/6)2
Sorry, I can not do a lookup without a good serial number - so you will need to remove the radio and get the serial number off the tag.
