Does anyone still respond to this post?
If so, I have a Becker CDR220
X5030258
Type 4462
Thanks....
"Does anyone still respond to this post?" -- about 4 or 5 times a week...
Try 6401
Hi, battery died, please help with radio code.
1999 911 C2
Becker CDR 210
R3297
W5024138
Thanks in advance
Paul
1999 911 C2
Becker CDR 210
R3297
W5024138
Thanks in advance
Paul
Try 0848
Worked great, thank you.
Hi all,
I have a 996 c4s MY2003 with PCM2. I want to change the battery. Need any radio code after change it or is it coded with instrument cluster or dme?
Thanks for help
Bye
Hi all,
Thanks for help
Bye
Plead read the Lost Radio Code FAQ here
Hello Loren,
The battery died in my 993.
Becker CDR 210
R2896
TS5001507
Thank you in advance,
Ivan
Hello Loren,
Becker CDR 210
R2896
TS5001507
Ivan
Try 8956
Hello Loren,
Becker CDR 210
R2896
TS5001507
Ivan
Try 8956
Thank you, but that did not work. I tried the 2 number increments, but no luck prevailed. Are there any other numbers I can try?
Hello Loren,
Becker CDR 210
R2896
TS5001507
Ivan
Try 8956
Hello Loren,
Becker CDR 210
R2896
TS5001507
Ivan
Try 8956
Please double check your serial number (on the unit) - it is highly likely the one you gave me is wrong.
Loren, you're right. The correct serial number is T5001507. I'm not sure if that is an S or a 5.
Sorry for the inconvenience.
Are you reading this off the radio it's self?
Did you try the display on the front panel instructions in the Lost Radio Code FAQ?
Code is still 8956
Yes, I am reading the serial number off the screen.. I followed the instructions exactly on the FAQ.
Code is still 8956
Code is still 8956
Then 8956 should work.
It worked! I just had to push the up key. Thank you very much for your time.
Code is still 8956
hi my sterio locked i cant get the code??
its a cdr-220 4462 48/98 serial x5013389
can anyone help???..
thanks
