Just push in the 4 numbers - no more no less.
As th FAQ says once you get a WAIT you will need to drive or have the ignition on for 1 hour to clear.
You did use the Lost Radio Code FAQ to get your serial number - right?
The serial # I gave you was done using the method for the Becker CR-210. My radio is the CDR-210 . The method went through with no problem . Didnt see a method for CDR-210 T500 1438
CR-210 and CDR-210 are the same procedure. So just enter the 4 digit code and give it a few seconds to come on.
Loren I went back and checked the # I first gave you and noticed I gave you the wrong # I am sorry for wasting your time. The correct # is T500 1438
Ok try 4820
Still a no go, I kept pressing it in and still no luck. I will try it when I drive to work. Thanks Phil
Ok, we got it! I pressed the station search button quickly after I put in the code you provided. Thanks a ton for your help, have a great day!
hi my frined.
i have porshe boxster model 2000
Radio code I reset disk.
What information do I need to get you to accept my code? Thank you
Becker 1
4462
Y5050795
Also, my radio is currently working but I don't have the code... is there a way of testing the code ?
Terry
Thanks so much Loren. 2 trips to my local dealer and they still couldn't find the code; I should have come here first.
BTW, did you happen to notice that the previous poster needed code 8676; I needed 8675. Weird. Thanks again.
