Hi, I just purchased a black 2001 Carrera 2 aerokit, and after replacing the battery with a new unit, I am in need of a radio code.
It's a CR-220 radio
Becker 1
Serial # 15040234
4363
24/99
Thanks in advance!
-Todd
It's a CR-220 radio
Becker 1
Serial # 15040234
4363
24/99
Thanks in advance!
-Todd
Try 2625
If those don't work and you have access to a DME reader, I believe it's listed under Vehicle Data
- Old Blevins
I replaced my battery a few months back and finally had the time to hook up the durametric since I remember seeing the code under vehicle data. I put it in and it doesn't work. So, they wasted time to put the WRONG code into the DME? And of course I have PCM so it looks like I have to bring it to the dealer in order to get the code from it, correct? I wonder what they are going to charge for that? Or I can just drive around without the pathetic sounding radio or outdated NAV :) :)
edit: Didnt realize I was in the boxster section. I have an '01 996TT
Edited by D_Nyholm
- Old Blevins
From the Lost Radio Code FAQ...
Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/OPC.
I need help With a Radio Code please.
I bought a 77 porsche with a 2000 Boxter Radio installed. Dealer cannot give me the code b/c I don't have a VIN #.
If there is a way anyone can get a code, it would really help.
Info:
2000 Porsche Boxter Radio
CR-210
Model-No: BE2182
Serial-NO: W5011655
EC: 102
993.645.117.01
Info:
CR-210
Model-No: BE2182
Serial-NO: W5011655
EC: 102
993.645.117.01
Try 4539
Info:
CR-210
Model-No: BE2182
Serial-NO: W5011655
EC: 102
993.645.117.01
Try 4539
Thank you Very Much!! It works.
This saves me from getting a new radio.
David
I have a 2000 911 Cab 996
CDR-220
Radio Serial number is
Y5038937
Can you provide me my code. I am about to change the Battery
Thank You
Try 3642
Thank you for the very quick turnaround. I will let you know how it goes
The Code worked great...
Well, I got the radio refurbished. Looks good but I haven't got the code. It came from my new to me 1999 Boxster.
CDR 220
BE 4462
W5006378
Thanks very much!
CDR 220
BE 4462
W5006378
Thanks very much!
Try 3141
Hello, I have a 2001 911 Carrera I changed the battery and lost the code.
Becker1 CDR 220
Type 4462
SER Y5040678
24/99
Thank you!!!
CDR 220
BE 4462
W5006378
Thanks very much!
Try 3141
Worked! Thanks very much.
